Carbed 5.0 Distributor recommendations
I am looking for a distributor to run on a non computer controlled carbed 5.0 in my 68 Stang.
From what I understand I need to use a bronze gear with the roller cam right?
I am going to be running the following:
92 5.0 stock block and pistons
Comp Cams XE-274HR
Edelbrock Performer 5.0 heads
FMS 1.6 RR
Looking to keep the cost under $250
Comp Cams XE-274HR
FMS 1.6 RR
2008 Audi A3 2.0T battle wagon
That is a negative on the bronze gear, you need to use the steel gear, if using a hydraulic roller. You are looking for MSD 8682 dizzy, I think that is it, and you can get the gear for 35.00 and have it installed for only 5.00 by calling MSD. You will have to get the distributor somewhere else though. I recommend Summit. You can use the bronze gear only for a limited time, before it grinds away at your cam gear. Check out www.carbdford.com in the tech section it has complete dizzy choices to use, what to look for at boneyards and various places.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
you can get a MSD billet for $205 from summit it comes with the gear installed for flat tappet cam. i just picked one up the other day for my 351W
Sweat thanks for the info, I was confused on the gear deal. I have a mallory unilite of my 289, but I was told it would not work and would need the gear anyway...
So for stock style cam, steel is the way to go correct?
i have abrand new 85 gt distrib from autozone I'll sell pretty cheap-pm me
" When you men get home and face an anti-war protester, look him in the eye and shake his hand.
Then, wink at his girlfriend because she knows she's dating a pussy." General Tommy Franks
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
