Air Suspension Question
Ok, hopefully you guys can help me out with this because i havn't been able to get a hold of my mechanic about this. Got a 99 crown victoria, hit a pot hole in it this past weekend and it fucked both tires on passenger side. I got new rims and tires on the car and the car sits about an inch higher on the passenger side. Im wondering if the air suspension got fucked up or if there's a sensor in there that might be reading wrong that needs to be replaced? I really appreciate your help because i have no idea when it comes to this car. thanx.
--brandon
--brandon
I didn't know Crown Vics had air suspensions
, I thought just the Lincolns had those. Sorry I'm not any help, free bump.
John
, I thought just the Lincolns had those. Sorry I'm not any help, free bump.John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
John
I do know that on Mark VII's there is a sensor on both front wheels and 1 in the rear. The sensor is located on the control arm. Looks like a little accordian with an arm that extends in or out. It adjusts the pressure in the air bag. If yours has moved it will let it think its to high or to low. They are adjustable on the Mark. They have 3 settings that you can see.
Only 1/4 mile track I know is Gandy Bridge
