Mcgard lug nuts, package of 5??
Old Dec 23, 2004 | 04:39 AM
T/S #25's Avatar
Need To Get Quicker
I have plenty of the short shank and long shank open end 1/2 X 20 McGard lug nuts here at the shop, but none of the mediums that I believe you are looking for.
Let me know if either of these styles can help you out in any way.
Joe
FordSpeed Racing
9.78 @ 136.05
www.fordspeedracing.com
Old Dec 23, 2004 | 06:56 AM
bitemark46's Avatar
Got traction?
Joe, I'm running a 1/2" spacer on each side and I just switched to 3" studs. I was thinking since using the spacers I would have to have the shank go through the spacers aswell. The long shank is 1" long. Do you think that it might bottom out all the way to the rotor? Or do you think I could get away with using the short shanks now that I have longer studs? -Mark
98' cobra
Old Dec 23, 2004 | 07:57 AM
T/S #25's Avatar
Need To Get Quicker
I would probably just mount the spacer and wheel on the car and take a measurment to see how long the shank can be.
With all the spacers I have found in the past, the lug nuts haven't actually gone through the spacer. The holes in the spacer have been just big enough for the studs but not big enough for the lug nut shank to go through. You might want to check that out.
Joe
FordSpeed Racing
9.78 @ 136.05
Old Dec 23, 2004 | 09:40 AM
bitemark46's Avatar
Got traction?
These I had to open up to fit the shank cause my stud barely stuck out the rim. That's why I needed a 3/4" shank. I don't think it'll pass tech at NMRA or FFW but it worked for the time being. I guess it really wouldn't matter now cause I went with longer studs. Do you have 10 with the short shank? How much ya asking for them? -Mark
98' cobra
Old Dec 23, 2004 | 03:03 PM
T/S #25's Avatar
Need To Get Quicker
I have plenty with the short shank. Let me know when you need them and I'll make you a smokin' deal.
Joe
FordSpeed Racing
9.78 @ 136.05
