HELP ASAP 4R70W trans change gone wrong
I was changing the fluid in my 2003 F 150 this weekend after having delayed engagment problems upon inital startup. Well at the bottom of the pan was a yellow plastic dowl looking thing with a half/semi circle on the other end with a black rubber o ring around it, looks like a seal of some time that would close off a drain valve if pressure was lost or something. Where does this go ??? PLEASE help, it's my daily drive and I have no wheel right now.
Guest
Posts: n/a
I think I know what you are talking about in a way, the yellow plastic dowel thig, looks like a fishing bobber? That are stuck in the pan at the factory so when it comes to change the fluid, it lets you know its never been changed before.
post a pic to be sure, but im sure thats what it is
