Gears and Cams etc....
Old Dec 2, 2004 | 06:55 PM
Super Coupe's Avatar
Old school TR member
Default Gears and Cams etc....
I am Looking into gettin pulleys, cams, and gears...........What should I go with on these........They are going on a stock 98' cobra...........also any sites/ shops that have good prices? thanks an advance
-Jaime
Old Dec 2, 2004 | 07:21 PM
1BAD347's Avatar
Whats in a Title
Originally posted by Mars_302
Buy a supercharger before you do cams. Cams are not cheap and not an easy undertaking. And wont see a whole lot either.
I agree, buy a Kenne Belle and a 4.10 gear. Get the car tuned and you should have about 500rwhp!! I know someone who can probably get one for you cheap
Old Dec 2, 2004 | 07:23 PM
1BAD347's Avatar
Whats in a Title
Oh yeah, don't waste your money on pulleys. You wont feel a thing and it wastes an hour of your time.
Old Dec 2, 2004 | 07:33 PM
78mphgpr's Avatar
under estimated
The best bang for your buck will be a timing adjuster, gears, maf, shifter and drag radials. That will put you in the mid to high 12's. Then spray it to mid 11's.
Old Dec 3, 2004 | 04:57 AM
n8secstangg's Avatar
i sort of agree with 78mphgpr....except for the timing adjuster, i would do a programmer in pace of the adjuster, not only is it better for performance it will allow you to install an offroad exhaust pipe without having to do MIL eliminators, you have a wider range of things to modify such as timing, fuel, fan control, it also has built in diagnostic ability...gimme a call at the shop today and i call help u price all these things out
chad
727-571-1996
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Dec 3, 2004 | 12:58 PM
tommygun's Avatar
^^^ gears, exhaust, SCT tuner, cai, shifter, tires.....easy mid 12s
Old Dec 3, 2004 | 03:53 PM
78mphgpr's Avatar
under estimated
chad
727-571-1996
When I had my 98, 2 years ago, the only way to adjust timing was with a T/A, I guess things have changed. I would also use a programmer if it was available.
