Help????????
Old Nov 30, 2004 | 08:10 PM
88stang5.0's Avatar
00 Yzf R1
Default Help????????
OK i put that new clutch in my car and went and started it and there is a clicking sound! The noise is gone or very slight when the clutch is disengaged and quite loud when it is engaged. I torqued everything to spec and have no idea what is making the noise anyone ever have this same thing happen?
Old Dec 1, 2004 | 06:43 AM
shinysideup's Avatar
TR Balla Donor Supreme
sounds like something was missed, or misaligned in the install. whatever it is, i would tear it down immediately(not drive it) this is only going to get much worse.
Old Dec 1, 2004 | 03:51 PM
stangerang's Avatar
whoopdy fucking do!
dunno what it could be........ check and make sure the clutch fork is on the pivot correctly ?????
maybe look in throught the fork cover and see if you can see or hear where it is coming from a bit better........
200 points away from a 300
Old Dec 2, 2004 | 11:31 AM
88stang5.0's Avatar
00 Yzf R1
ok someone told me that same thing how can i make sure it is on right and how could it be on wrong isnt it only go on one way? And with the throwout bearing does it go under or over those 2 little metal prong things? thnx
Old Dec 2, 2004 | 11:38 AM
gangstasurfin's Avatar
stanglvr
i have an 03 mach 1 and i just took mine up to ford today to get mine checked out, it makes a ticking sound from the engine mostly on the the driver side, and they returned it to me saying that this is typical among the 32 valve engines(cobra and mach1), so all they did was torque some screws and gave it back to me, and said that this is and has been under investigation, also they said this does not effect the performance in any way
