ignition/starter motor help
Old Nov 14, 2004 | 11:45 AM
suprapimpa's Avatar
Unhappy ignition/starter motor help
Well the ignition is broken I think, I'm on a low budget so I'm trying to do anything in order to start it without having to replace it. Here's the deal I have a Haynes manual and it says:
"6. To check the solenoid, connect a jumper lead between the battery (+) and the ignition switch terminal (the small terminal) on the solenoid. If the starter motor now operates, the solenoid is OK and the problem is in the ignition switch, Neutral start switch or in the wiring."
My question is, what is a jumper lead? And if it works and the starter motor turns can I start the car using just the jumper lead to get the engine to crank over?
I know the starter motor works because the ignition used to turn over, but when I installed the new carb the key wouldn't turn the ignition anymore and the steering wheel locked. I just need this car to get started because its for a science fair project and the due dates getting closer. Can anyone help?
Old Nov 14, 2004 | 09:34 PM
shinysideup's Avatar
TR Balla Donor Supreme
is this a joke. ? pull the dam wheel when u go to turn the key, it will unlock the column. then turn key.......
Old Nov 14, 2004 | 09:43 PM
EsCoRtLvR's Avatar
Escort Connoisseur
I used to work at a Ford incoming call center at a dealership, yes, people sometimes don't know that the steering wheel locks like that . You'd be surprised how many people didn't know that their car won't go anywhere when their brake lights are out too (newer ones that is) .
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Old Nov 14, 2004 | 11:14 PM
ex-AAA locksmith. seen it all.
gone in 60 secs is such bullshit! the way they gain entry,pick locks, is so wrong. i would open everything ; less than the newer BMW. its all hype and glam. the locks on the mustang are for show, they are a joke.:bbb:
Old Nov 15, 2004 | 11:29 AM
suprapimpa's Avatar
I'm not that dumb, the key won't turn the ignition. If the steering wheel locks I can jiggle the ignition and unlock it to turn but the key still won't turn.
Old Nov 15, 2004 | 04:44 PM
if the key wont turn, it is not a problem under the hood. if the key will turn enough to unlock the wheel , it should also rotate to "start" position. maybe u can watch one of your friends how they start their cars? thats what friends are for.
Old Nov 15, 2004 | 04:59 PM
ODB's Avatar
ODB
S.Y.L.O.
