Question on injector size
Old Nov 10, 2004 | 09:25 PM
bottlefedLX's Avatar
Don't be so angry
Default Question on injector size
I am planning on a set of Trick Flow TW heads, Trick Flow intake, 1.6 rocker arms, Trick Flow cam, 70mm Throttle body. In Summit Racing, they sell this kit and advertise 350 horsepower. These parts will be added to my headers, off-road H-pipe, pullies, Pro-Flow 75MM air meter, MSD-6A, and Blaster coil. I also have a 125 shot ZEX kit. My question is what size injector do you guys think I should run? is 24lb enough or should I got to 30lb injector? Also, has anyone here ever sent off a Pro-M (Pro-Flow) meter to be recalibrated? I can't find any info on the web. Thanks, in advance, for the help.
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
Old Nov 10, 2004 | 11:14 PM
Don't be so angry
what happens if you use too big of an injector, i.e., use 30#'s when 24#'s would be adequate. I may go with a blower of turbo later and just don't want to do this twice.
John
John
Old Nov 11, 2004 | 12:44 AM
Don't be so angry
The ZEX kit is a dry kit. I was not sure between 30# or 24#. I was myself leaning towards 30#. I still have to get a matching air meter, so I don't want to mess up. I hoping for Vince to chime in because he said on another thread not to get a C&L meter and I am curious why. Thanks for the info.
John
John
Old Nov 11, 2004 | 04:34 AM
TheShow50h's Avatar
The little 5.0 that could
John
I believe the cause of my surging idle and occassional stalling is the result of my c&l. The car can't maintain a constant a/f either. If I had to do it again I would have went with a pro-m 80mm. I'd go with 30s, that's what I'm running.
-Vince
Old Nov 11, 2004 | 04:44 AM
n8secstangg's Avatar
you can print out a recal form from www.pro-flow.com the recal form link is on the left, go with 30's
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Nov 12, 2004 | 12:39 AM
Don't be so angry
Thanks Chad for the link, I guess on my work computer, it would not allow access to the site for some reason. Any idea on the price for recal? Also, thanks for the responses, 30# sound good to me, too.
John
John
Old Nov 12, 2004 | 05:34 AM
mx-4u2nv's Avatar
I have almost the same set up that you have and am running 24lb injectors and they seem to be just fine for me.
"Been educating 4drwhore since 11/24"
Originally Posted by Na306StAnG
I only date chicks with down syndrome this way I know from day one their fucking retarded.
Old Nov 12, 2004 | 12:23 PM
Don't be so angry
Do you mean what I currently have or including what I plan to add? If you mean with all I plan to add, what kind of power do you make and what does you car run? Thanks for the info.
John
John
