Changing non-roller block to roller
Old Nov 5, 2004 | 04:51 PM
92coupe50's Avatar
Default Changing non-roller block to roller
I've talked to several people and they all tell me different things. What all do I need to convert a non-roller 351w to a roller 351?
Old Nov 5, 2004 | 10:29 PM
race495's Avatar
Pull Over
Aftermarket roller lifters and a small base circle cam is one way.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old Nov 6, 2004 | 02:47 PM
92coupe50's Avatar
Thanks, for the help. I appreciate it
Old Nov 7, 2004 | 08:17 AM
race495's Avatar
Pull Over
Here is an article I came across.
http://www.fordmuscle.com/archives/2...on/index.shtml
Old Nov 7, 2004 | 10:18 AM
HELMUT RONER's Avatar
USAFR Veteran
You don't need to tap the lifter valley to install a spider and dogbones. That's just one way to do it, but camshaft selection is limited when using small base circled cams. Crane and Comp Cams make link-bar lifters to run a late model hydraulic roller cam in a non-roller ready block. These lifters aren't cheap, though, so it will depend on you how much time and effort you want to put into tapping the lifter valley for the spider retainer. Remember one thing, if you going to make serious power with the motor the blocks tend to split down the middle most of the time and that's where you'd have to tap the retainer holes.
Link to Crane Lifters on Summit Racing
Helmut
