changing fox front rotors
Old Nov 4, 2004 | 03:12 PM
Leonard's Avatar
OUCH!!!
Default changing fox front rotors
I'm getting ready to do the 5 lug conversion on the cobra and I"ve got two questions....
Are new wheel bearings a requirement, or can I get by without them.
Anybody know what size the castle nut that holds the rotor/hub on is? I'd like to make sure I have the right size socket before I take stuff apart. I HATE trips to the store for stuff I'm missing.
Old Nov 4, 2004 | 06:47 PM
n8secstangg's Avatar
depends on the condition of the bearings u have...if they are ok then u can reuse them with no problem...i always make sure i clean all the old grease out of them and repack them with all fresh grease...dont worry about a socket, use a large crescent wrench and u are good to go...when u are installing thew rotors turn the castle nut till it starts to get pretty snug..then back it off 1 recess in the lock collar..you dont want them too tight or too loose...good luck with the change over...5 lug is definitely worth it..
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Nov 5, 2004 | 03:25 AM
Leonard's Avatar
OUCH!!!
I got the Ford Motorsports conversion kit. The hub/rotor is identical to the 4 lug except for the lug pattern. It has the slanted areas built in to it for the bearings to seat on. Even came with a grease seal for the back side.
Old Nov 5, 2004 | 05:45 AM
shinysideup's Avatar
TR Balla Donor Supreme
good to go !
Old Nov 5, 2004 | 01:18 PM
Alan's Avatar
drives euro trash
You wouldn't happen to still have those SN95 spindles/hubs? If you don't need them, I may want to buy them from you in the near future if you're thinking about getting rid of them.
Old Nov 5, 2004 | 02:26 PM
Leonard's Avatar
OUCH!!!
yeah. i've still got them. i would consider selling them back. I won't bee needing them anytime soon. want the brakes too?
Old Nov 6, 2004 | 05:03 AM
Alan's Avatar
drives euro trash
Cool. In about a month I should have the money scraped together to buy them from you. Don't need the brakes though.
Old Nov 6, 2004 | 05:14 AM
Leonard's Avatar
OUCH!!!
Originally posted by Mars_302
what brakes do you have?
94+ gt single piston.
