How much hp do I have?
I want to know if someone could give me an idea of how much hp I am playing with?
Here is what i have, cobra u/l, 24# injectors, c&l 73mm for 24# injectors, ajustable fuel reg, 190lph pump, GT40 cast iron heads, 1.72 rr, stock push rods& lifters, stock cam, new timing chain, mac pullies, edelbrock high flow water pump, 3 row radiator, black magic fan,97 degree thermostate, fender wall cold air filter, 65mm trottle body,timing is set at 10 degrees, stock diff,mac equal length headers, mac h-pipe, flowmaster muff's, 3550 tremec trany, ford motorsport fly wheel, ram heavy duty clutch, thanks for any info!!!!!!!
Depends, could not be running to it's potential. Cam is degreed wrong, timing off, too rich, too lean... etc, etc.
Get it on the dyno. Fordspeed will do you right.
11735 66th Street
Largo, FL 33773
Tel: (727) 549-8255
11735 66th Street
Largo, FL 33773
Tel: (727) 549-8255
-Vince
-Vince
Originally posted by pushmyrod
i hear racingtheburg has 150 or 160 some with shit done
Whatever the purpose of your post was, I'm not sure.
Mine has gt40p's with cam and edelbrock intake and made 282, but my car is completely different than his. He could make the same #'s, or he could make a lot less. Only way to know is to spend 100 bucks and have an hour dyno tune.
-Vince
-Vince
There is an off-the-shelf Crane cam that works well with those heads and the combination that you have. Let me find the part number and I will post it here for you.
