cams for the 4.6L DOHC
Old Sep 19, 2004 | 04:29 PM
seventhgear's Avatar
hanglike sleeve of wizard
Question cams for the 4.6L DOHC
what cams are good for a 4.6l DOHC ?? would they need to be custom grinded or what not? and what will i be looking to spend on cams,springs,etc all together?
thanks in advance
jack
image removed from your sig...see forum rules
Old Sep 20, 2004 | 09:34 AM
bitemark46's Avatar
Got traction?
You can get regrinds for alittle cheaper. But depends on the setup you want to the type of cams/specs. Check Houston Performance, Mod Max, Comp Cams( I believe has mod motor cams), or Leverious(sp?) Motorsports for pricing. A 4v is a bit expensive for cams since not the demand isn't as high and you have to buy 4.
-Mark
98' cobra
Old Sep 20, 2004 | 10:03 AM
pjb03's Avatar
Check out the Crower/JDMs, I have their cams. You can expect to pay $1500 or so with springs and retainers.
Give JDM in NJ a call. Ask for Anthony, they have their own grinds that are made by Crower. 732-780-0770. A Crower/JDM cammed 03 Cobra has gone 9.40s with no spray.
If you can wait a little while, Lunati and Jesel have some interesting things coming out like rifle drilled cams and roller followers.
I have a set of 03 Cobra cams If you are interested
Is this a boost, or an N/A setup?
93 Saleen Spyder #53 H/C Novi 2000
05 Rubicon Lifted, ect
13 BMW S1000RR, 10 R1200GSA
14 Honda Grom
12 KTM690 Enduro R
Too many old bikes and mini bikes to list.
Old Sep 20, 2004 | 01:33 PM
smokeshow's Avatar
Slower Than Dial-up...
Crower or Comp cams both should be able to help you out. And $1500 is about what it's going to set you back.
Old Sep 20, 2004 | 05:53 PM
im going n/a maybe some spray a while down the road but not going to be boosted... thanks for all of the info but im looking to moderately mod the cobra i have without going after the pistons/rods etc. then maybe later i will change those.
once again thanks for the input
jack
Old Sep 21, 2004 | 12:18 AM
mustangman98's Avatar
Mullet Powered
the 4.6L cams are expensive as fukk, so dont be surprised when you spend almost 2k just on a good set-up on your stock heads. but you will see good power gains with a good mild cam from crower/crane. ive seen some 4v motors make almost 50rwhp with a cam and spring swap.
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Sep 21, 2004 | 05:09 PM
thanks for that info mustang.... i am expecting to pay out my ass for these tho... just will prolly leave this mod till last..... ohh and another thing.... emissions on my 97 cobra..i want them off kuz emissions in florida are gay n e ways... should i remoe them? is there a proper way to remove them or what not? b/c i think alot of that emission shit is electrical
thanks
jack
Old Sep 21, 2004 | 09:15 PM
Mullet Powered
well, im guessing you talking about removing your catalatic converters? it very simple and easy to do, either find a back woods exhaust shop to cut off the cats and weld in a piece of pipe, or buy yourself an off road H-pipe or X-pipe. after you purchase the pipe buy what is called MIL eliminators, pretty much any speed shop in the area will have them in stock or order them off of www.uprproducts.com, they have a nice set-up that you just plug into you stock harness and its ready to go. after you get the pipe on you put the MIL eliminators in between you O2 sensors on the mid-pipe and the factory plug on the harness. its really simple, you have any more ?'s just ask.
03 Gt - SOLD!
Old Sep 23, 2004 | 05:28 PM
no... the cats are eliminated and an H-pipe with Mac exh to the rear. i was talking about like the elctronic emissions or what not... i know there has to be a smog pump somewhere behind the fenders or what have you... am i making n e sense? id like to remove n e thing that has to do with emission control. im new to the cobra scene but i do know alot about mechanics yet knowledge is limited when speaking of electronics.
the MIL eliminators... what exactly do they do? fool the ecu to believe the engine has cat's? i have yet to sit underneath the car and look for simple things such as that ..... i bought a steeda clutch cable double hook adjuster i believe its called because with the upgraded clutch and short shifter shifts are acting wacky... n e ways im all off topic pm me or something maybe we can meet up on friday or saturday and and you can bring me up to speed on these DOHC engines. thanks again
jack
Old Sep 24, 2004 | 04:24 AM
Mullet Powered
yeah, the MILeliminators just fool the ECU into thinking the cats are there and also elminate the "Service Engine Soon" light on your dash.
as for a smog pump, i think only cars sold in California come with them installed. i may be wrong but someone else may know.
03 Gt - SOLD!
