So how does this look on my car ?
I take it your not going the SCCA route then, eh?
Jeff
Jeff
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Jeff
Guest
Posts: n/a
Originally posted by BigBadBuick
Looks good, but see the front lower corner of your wheel well? That's the groove cutter I was telling you about
Yeah but once we loosen the double adjustable upper control arms and reposition everything that issue will be solved.
adjusting the upper control arms won't throw the geometry "out of whack" if done properly (which I'm sure Coastal will do). He obviously has to keep an eye on his pinion angle and make sure the rear stays square from side to side. Not sure what lowers he has, but probably what will need to happen is if it's anything like my lowers, they'll have to cut the welds on the LCAs, adjust the positioning of the LCA and UCA, reweld the LCA.
I am your penalty.....
Guest
Posts: n/a
Don't worry BBB I don't half ass things as much as you might think.
And I am actually quite the worry wart about the most minuscule details, guess that's why my car hauls ass and drives straight eh ?
I have already made some calls regarding how much play I have with adjusting the control arms and not messing up my very important pinon angle.
Hopefully not much will need to be done and certainly hope nothing needs to be moved around.
Derek, I have the Southside LCA's..
Originally posted by Gunslinger09
Dang ole big tires on that Turbo Mustang.
'99 GT 35th Anniv - 13.01 @ 107.4 w/ cams & bolt-ons - Sold
'03 Audi A4 1.8TQ - :gordy:
► Home Buying & Selling Finance Tips ◄
[/b]
[/b]
