bent pushrod
I went down to sunshine wednesday and on my 3rd pass i pulled to about 5200-5400 rpms 1st and 2nd, and just got it into 3rd. i just let it coast to slow down. The car slowly died by the time i got to the last turn off. The car would start again, but had a really hard time keepin its idle. I got it towed home then did a compression test. Cyl #2 had no compression at all, but all the others where all within 10 psi of eachother. I originally thought i bent a valve cuz i got stock springs with ported e7's.i pull the valve cover today and the pushrod is just sticking out the side of the rocker . I was just wondering if anything else could have been damage from this?
WHOA CHECK A PISTON!!!!! dude if it did that that means could be alot of other things.... milled to low and hit a piston making the rocker go back and hit the rod OR could of floated a lil caught it off beat and BAM hit the rocker hard to say Id say look at your piston bro
Yep - if the pushrod was bent and that was it - then you would have compression because the valve would be closed.. Ive never seen a bent pushrod without its "little buddy" - Bent Valve.
Sorry man.
Jeff
Sorry man.
Jeff
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Jeff
I did do a compression test. NO compression at all in that cylinder. so pulling the head is a must, and i guess while its off ill get some spirngs on there. Any idea on good springs? I was looking at comp cam, but theres so many to choose from. Double springs needed for juts a e303?
-thanks
-thanks
-thanks
-thanks
http://store.summitracing.com/defaul...0100&x=10&y=10
"This kit includes everything you need to install a high performance cam with up to .542 in. of lift on a small block Ford with OEM cast iron heads. It includes valve springs with dampers, chromemoly retainers, valve seals, locks, shims, and a spring height gauge. This kit provides 110 lbs. of seat pressure at an installed height of 1.800 in."
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
ya i am, i dont plan on gettin new rockers. Ive decided to go with a TF cam and springs. would the stock pushrods and lifters still be good? WHen i put this back together its gettin done right this time
