Locked out of my car!!!
Next time try a brick: fast, simple, and effective.
The sn95's are fairly easy to break into. Since the door has no frame around the window, you can pull back slightly on the window and put a coathanger between the glass and the soft rubber gasket at the rear edge of the glass. It is pretty much a straight shot to the power doorlock switch. We did this a few times at the car wash I use to work at when I was in highschool.
Originally posted by 351coupe
Ahh,Steve,I see you know the "fox easy entry"trick!
Yeah I had some cuban guys show me down in Miami. Needless to say I removed the door rod right after.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Good thing about having them busted, someone tried to break into my car and was unsuccessful because all the key hole does is turn.
-Ryan-
-Ryan-
