Shifter rattling ...
Well, it started probably 5-6 months ago, it was faint and bareable. More recently, the rattling is starting to get very aggravating and it gets louder with speed. It only makes the noise while maintaining a constant speed. Durring decel and accel the noise doesn't exist, unless at wot. When I try and hold the shifter steady with my hand the noise still continues.
Any ideas on what this could be and how I can fix it?
-Vince
-Vince
u joints, time for upgrade, get under the car and see if you feel play with the drive shaft,clunk, only a few bucks
Pro 5.0 and almost every other shifter on the market rattle like that. They usually do it more under load though.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Jeff
The cure to your problem is a built AOD.
Just kidding man...
I'd check the u joints also....
If your d/s is a problem - I have one sitting in my garage from a 95 GT automatic (not sure if it'll work for you) that you can have...Its in fine condition...besides all the spider webs on it from sitting for a couple years.
Just kidding man...
Current Rides: 2001 BMW 540i, 2002 BMW 330i (wife's car)
Previous Rides: 2001 Saleen Mustang SC Speedster Convt, 95 Mustang GT w/ Built 331/Vortech S Trim - 550rwhp, 93 Mustang LX Procharged 400rwhp, 99 SVT Lightning 475RWHP
I'll check the driveshaft tomorrow. If something is wrong with the driveshaft itself I'll just pick up an aluminum one since I have the money, thanks for the offer though
__
I was aware that all aftermarket shifters rattle, but this seems abnormal. There is a lot of vibration in the car under wot as well. I'm sure it's either the u joints or the driveshaft itself.
-Vince
-Vince
Originally posted by TheShow50h
My car is slowly turning into a 95gt,
i dont know what kind of transmission you have, but i have a tremec 3550 and it makes a good amount of noise, especially in 3rd gear. when i bought the transmission, i was told it was going to make noise, and every car i have been in has made the same noises. tremecs are known for it. but its not that loud, so it probably isnt that.
but check out the u joints, that would be your best bet, like its been said already
