gears
Old Jul 1, 2004 | 04:07 PM
Lumberjack's Avatar
is made outa laffy taffy
Default gears
i just bought some 4:10 gears for a sweet deal and i was wondering if any of you knew any place to get them installed for fairly sheap. im kinda strapt for cash at the moment and want to get these things in before track day... thanx
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old Jul 1, 2004 | 05:48 PM
MustangMosachi's Avatar
Breaking the Broken
Default Re: gears
try race related....
"Try to make ends meet
You're a slave to money then you die"
Old Jul 1, 2004 | 05:55 PM
TheShow50h's Avatar
The little 5.0 that could
Default Re: gears
Fordspeed or Race Related, both should be around $275-$325 I'm guessing.
-Vince
Old Jul 1, 2004 | 07:54 PM
TheShow50h's Avatar
Originally posted by Zate
Coastal.
+1, I'd reccomend rr, fordspeed, or coastal. Which ever one is closest is the one I'd goto,
-Vince
Old Jul 1, 2004 | 09:24 PM
BLUE2KSS's Avatar
Mechanical Engineer
shit, any one of these shops will do an awesome job
which ever is closest to you is where i would go
Old Jul 2, 2004 | 07:36 AM
HAVIK's Avatar
Is That Turbo? Psssst!
or blue oval corral
Old Jul 2, 2004 | 12:40 PM
y3110w 5tang's Avatar
i have the same gears in my car and i bought them and had them installed for 400 done at blue oval corral its on the same road as sunshine drag strip.
Old Jul 2, 2004 | 01:20 PM
Stangonline's Avatar
Or you could do it yourself and save some $$, like I did. You have to kinda be lucky though. I was able to use the original shims - I replaced my gears with motorsport gears and everything Mic'd out perfectly.
http://www.corral.net/tech/drivetrain/gears.html
Jeff
www.stangonline.com
Old Jul 3, 2004 | 05:34 AM
James @ Race Related's Avatar
fab1up
All listed are wise choices,we can take you in right away and have you out in 3 hours tops.Guarranteed to be to your liking.
James www.racerelated.com
James @ www.racerelated.com
Shop#727-561-9440
