need help with 94 gt
just installed mac equal lenght headers today....what a pain in the ass........made quite a bit of difference..........but now with the x-pipe and the headers on ,seems to be running really rich......and idles rough after running hard. do i need to get a chip and program it to fix this....any ifo is appreciated....thanks
sdsd
sdsd
2013 Base Mustang GT - Tampa Stock
Did you install the X at the same time?... if you had to take the 02s out of the stock Pipe and installed them into the X you probably pissed them off. I had a similar problem when Sam@Coastal did my install. Had to buy new 02s... You should drive it for a day or 2. To give the Computer time to "re-learn" and if still having problems try 02s...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
could be an exhaust leak, check for leaks.........
also as said, adding an O/R h pipe x pipe will richen it up a bit anyway, and you will lose a bit of bottom end torque.......
200 points away from a 300
Originally posted by mustangman98
MIL eliminators?????
i didnt put them on when i put in the o/r H-pipe and my car ran like shit until i put them on.
thanks for all the help... seemed to be running a little bit better today. I installed the x pipe about a month ago and it has been running rich since then. i did put the 02 sensors on the x pipe and they seem to be working fine... after i installed the headers is when i noticed it was running really rich and idling a lot rougher.. but it did a little bit better today, so im gonna give it time.. i havent put the mil eliminators on yet cuz im on a budget. also its weird cuz when i installed the x pipe a while back my check engine light was coming on all the time... but hasnt come on once yet since the header change seems weird to me... anyone know what could cause that? Thanks
sdsd
sdsd
You can't put mil elims on a '94, there are only two o2 sensors. The computer will start adapting to the changes and it will run better. You can also disconnect your battery for 30-60 minutes and then start the car. It should re-map all the parameters.
