Stripped bolts!!!!!!!
They sell special bits that are specifically designed for that. Some auto parts stores carry them, but your best bet is Sears.
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
stripped screw and bolt removers.
where are you at?
i have a set if you are close, ill come to you if need it really bad.
let me know, 727-460-7189 Dustin
where are you at?
EaseOut.. or Easy Out... they are like a inverted drill bit.. You grab the right size that fits in the head of the screw(bolt) and you tap in in with a hammer.. its left hand thread to the more you turn it... the more pressure you put to remove said screw(bolt)... hope that helps...
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
