cam questions
Old May 5, 2004 | 07:12 AM
Lumberjack's Avatar
is made outa laffy taffy
Default cam questions
i am looking to put a new cam in my stang i have 1.72 roller rockers on it and am thinking about going with the b-303 cam i think anything higher lift of a cam i might have a little problem with valve to piston clearence. are there any other cams i could use with better gains? thanx for your help
All-American Street Car Performance
6187 126th ave north
Largo Fl 33773
727-667-9346
www.aastreetcars.com
Old May 5, 2004 | 08:46 AM
BLUE2KSS's Avatar
Mechanical Engineer
i think you might be able to run the E303.
you still have the stock heads in there right?
Old May 5, 2004 | 09:05 AM
Lumberjack's Avatar
yeah stock e-7 heads i beleive. how much of a lift will i be ably to run on stock heads and 1.72 rockers? thanx for your input
Largo Fl 33773
727-667-9346
Old May 5, 2004 | 09:12 AM
Lumberjack's Avatar
so do you think the E cam would be pushing it?
Largo Fl 33773
727-667-9346
Old May 5, 2004 | 11:37 AM
Lumberjack's Avatar
what do you think the average hp/tq gains are with the B-cam over the stock one?
Largo Fl 33773
727-667-9346
Old May 5, 2004 | 11:49 AM
TheShow50h's Avatar
The little 5.0 that could
On a motor with stock intake/heads .. it's going to take away some low end power and not give you any significant gains up top .. maybe 10-15rwhp.
-Vince
Old May 5, 2004 | 11:54 AM
Lumberjack's Avatar
THANX GUYS
Largo Fl 33773
727-667-9346
Old May 5, 2004 | 12:00 PM
Lumberjack's Avatar
ARE THERE ANY OTHER CAMS ANY OF YOU MAY KNOW OF THAT MAY BE BETTER?
Largo Fl 33773
727-667-9346
