Fluid Leak
Dripping off of the front passenger subframe right up by the firewall. (89 5.0 Coupe). I can't see where it's coming from. It shouldn't be the A/C as I haven't even turned it on (and doubt that it works).
Maybe the heater core it's conection from the block?
I'd guess the heater core itself. Mine was bad on my '87 GT and it was draining off the subframe exactly where you explained it. If I were you I'd just splice them together and be done with it. It's not like you're going to need it anyway with it being Summer soon and you're going to be tearing it apart anyway.
2013 Base Mustang GT - Tampa Stock
Originally posted by Leonard
Which way is better/easier to bypass it?
Just get a coupler and connect the two lines ?
or
Remove the lines and plug them where they originate on the intake?
or
is there any burping involved in getting air outta the lines once i put the coupler in or will the water pump push it through?
