Need Mass Air Help
Old Apr 11, 2004 | 10:01 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Default Need Mass Air Help
I have an 87 LX t-tops with from what im told rare grey interior. Its speed density and I want to change it over to mass air. Without buying a 600$ kit what parts would I need from a donor car to complete the upgrade? Do I have to install the FULL wiring harness from the donor car?
Derp!
Old Apr 11, 2004 | 10:12 AM
mustangman98's Avatar
Mullet Powered
i would goto a junk yard and find a donor car and get the whole kit for $100 and yes you need the full harness to make it work.
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Apr 11, 2004 | 10:37 AM
69Boss521's Avatar
Is there a specific Computer I need? The car has a metric AOD, the car was originally a 5spd, it still has the clutch pedal and everything. Should I get a auto computer or manual computer?
I need:
Computer
Harness
Mass air meter w/bracket
Cold air pipe
what else?
Derp!
Old Apr 11, 2004 | 04:03 PM
HELMUT RONER's Avatar
USAFR Veteran
What are you going to do to the car that you need to convert to mass air? Unless you're going to be installing a bigger cam, intake and heads there is absolutely no need for it as there is no power to be gained from just a swap alone.
For a 1987 5.0 an entire engine harness from a 1988 California 5.0 or an '89 5.0 is a direct swap being that those years have the MAF sensor harness integrated into them while retaining all the same exact connectors and wire colors for those years (1987-1989; possibly '86, too). Used computers at $100 or more are a ripoff. Remanufactured EEC cost the same and work just as well if not better. I rewired my '88 for mass air back in December of '98 using a Standard™ part # EM073 (A9L or A9P designation unecessary) for $104 with a junk EEC I used as a core exchange at the parts store. Go to the junkyard nearest you and cut out a
MAF sensor harness from a late 80s-early 90s Aerostar, Tempo, Escort, etc and cut out the harness connecting to the EEC along with some length of wiring. Remove pins from junk EEC connector and solder the wires going to the donor MAF harness. I have to look up again in my old paperwork which # pins have to be moved and added. I don't think I spent more than $150 on my swap. It takes patience and time. I scavenged a MAF sensor from an early '90s 5.0 Thunderbird. Works great, although now I'm at a stage where I need to upgrade it.
Helmut
Old Apr 12, 2004 | 05:25 AM
69Boss521's Avatar
Thanks guys for your help, yes I plan on doing major upgrades. So what ARE the can's and can'ts of speed density. What can you install and what can't you?
Derp!
Old Apr 12, 2004 | 06:09 PM
USAFR Veteran
Comp Cams has grinds specifically made for speed density cars. You can give them a call and find out how much it'll run you.
Helmut
