Cleaning Fuel Rail
Old Feb 24, 2004 | 07:39 AM
Alan's Avatar
drives euro trash
Question Cleaning Fuel Rail
My fuel rail just arived at the office today. It had been sitting for quite a while unused, and there seems to be a little surface rust on the inside of the rail. What is the easiest, best, and quickest way to clean this out myself? I'm concerned about particles dislodging and screwing up my brand new $600 injectors.
I appreciate the help.
Old Feb 24, 2004 | 12:15 PM
steve's Avatar
madpom
here we go again scott with his carbs hahaha
if you go to homedepot you should be able to get a file the same size as a pen that might fit in there
Old Feb 24, 2004 | 12:43 PM
plazma's Avatar
Go to Home depot or lowes and get the flexable wire brushes that the plummers use for cleaning out the inside of pipes. I think they are about 3 bucks.
How the hell did you spend 600 dollars on injectors?!? I'm damn curious to hear this because you can get low impedence injctors up to 108pd for like 350 a set.
Old Feb 24, 2004 | 03:00 PM
stangerang's Avatar
whoopdy fucking do!
soak it in gasoline! its a great cleaner/ solvent..........
200 points away from a 300
Old Feb 24, 2004 | 03:54 PM
Alan's Avatar
drives euro trash
Carb cleaner seemed to do the trick.
Plazma. $600 for NOS Ford injectors. I looked everywhere on the Internet, asked a few SVO people, and couldn't find any low impedance injectors...nor any used ones. I was in a relative time crunch since my injectors were spraying gas all over the intake manifold, so I took it like a man and went to Brandon Ford.
Old Feb 25, 2004 | 02:32 AM
race495's Avatar
Pull Over
What size injectors did you need?
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old Feb 25, 2004 | 04:59 AM
Alan's Avatar
drives euro trash
35lb injectors. I could upgrade to 42's with no problems, but I couldn't find those in a low impedance either.
Old Feb 25, 2004 | 10:02 AM
Steve B's Avatar
brings his heater.
Originally posted by Mars_302
arent the new lewer lightnings low imp?
doh!
