removing egr
Old Feb 18, 2004 | 10:49 AM
superdave's Avatar
Default removing egr
I should be putting the new engine in the car sometime in the next 2 weekends, so i'm trying to get as much cleaned/modded as possible before doing the swap. I searched through a couple different forums and didnt really find a good answer, so here is the question:
Are there any cons to pulling off the EGR valve and capping all of the lines?
I know that it will help keep hot exhaust gasses from getting into the intake, as well as keep things a little cleaner. I can also fab up and powder coat a peice of aluminum to cover the hole on the upper intake and keep it matching to my color scheme. Am i going to hurt anything by pulling this off?
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Old Feb 18, 2004 | 11:02 AM
N20D5OH's Avatar
All I did was cut the tube and block it off on both ends. It didn't hurt my car a bit driveability wise, but that was on my 5.0. I'm not sure what car you're doing this on so I don't want to tell you it won't bother it unless it's on the 5.0. I would say it won't on either car though.
2013 Base Mustang GT - Tampa Stock
Old Feb 18, 2004 | 11:05 AM
Alan's Avatar
drives euro trash
The only con that comes to mind is that it may throw a check engine light on the OBDII cars.
Old Feb 18, 2004 | 05:31 PM
the anti-rice's Avatar
finally painted the car!
do a search on Corral in the SVT DOHC forum. its been asked numerous times and i still cant remember the pros/cons of it.
-Ryan-
Old Feb 18, 2004 | 05:41 PM
Alan's Avatar
drives euro trash
Almost forgot to mention that removing the EGR will fail your car come time for emissions. I know you don't live in FL, so you may want to check into that with other local Mustang folk.
Old Feb 19, 2004 | 05:10 AM
superdave's Avatar
right now, although memphis requires emissions testing, the outlying county does not, and my car is registered in the county. i may run it through just for the sake of trying, as i am curious of the before-after effects of the new motor.
Dave
Old Feb 19, 2004 | 07:10 AM
Alan's Avatar
drives euro trash
I should have been more specific. Removing the EGR will fail you on the visual inspection, not the actual sniffer test.
Old Feb 19, 2004 | 08:39 AM
superdave's Avatar
gotcha. here in memphis we dont really have a visual. they just check for smoke (by making you rev the hell out of your motor) and check the emissions.
Dave
