Head Swap ...
Old Jan 23, 2004 | 07:50 PM
RaNgEr OwNz's Avatar
show we can probly take it to andys house one afternoon and work on it! you should get some new roller rockers while its apart!
Old Jan 24, 2004 | 05:37 AM
Strokd85's Avatar
Daddy-O
i've got some quality dove 1.7 rockers if you need a set. also, with the lifters, snug up the locks finger tight (you should be able to feel some friction when spinning the pushrod when they are correct, tighten the lock and then ad a 1/4 turn to the nut to add the pre-load if I remember right... it's been a while since I did hyd lifters.
I also have some ARP bolts that you could probably use, I believe they are 7/16" but have to check.. They'd be yours cheap...
I am your penalty.....
Old Jan 24, 2004 | 06:45 AM
bignastygt's Avatar
only the nasty survive!
get brand new head bolts!
my friend used some old ones and on one bolt the threads were stretched and fuct all sorts of shit up and had to pull the heads back off buy new gaskets and new bolts. just spend the
$40 and get it right. also if you torque em down to much that is how you strectch the threads.
Old Jan 24, 2004 | 07:10 AM
TheShow50h's Avatar
The little 5.0 that could
how much for the bolts and rockers bro?
