Well I'm stressed out and can't take any more........
Scott,been folowing your progress on TurboStangs.com and it sounded like everything was going well.What happened?New carb,new regulator,what else,could it be the return line?
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Guest
Posts: n/a
The carb I had was to adjustable and created a bad dead spot off of idle so I got a top of the line purpose built turbo carb. and it is as responsive as EFI.. The regulator issue was due to some dumb fuck selling me the wrong one, Fed Ex'd a new one in today and it fixed the problem.
Now the wastegate / boost controller wants to be a little bitch but that will get worked out tomorrow. It did make 14 lbs on the rollers this afternoon for about 2 seconds and it sounded mean as hell !
This is what happens when you build a set-up that many others have not done and stuff like this is going to happen on any new motor / power adder combo it just takes a little time.
Well good to see you stuck with the carb,you'll get it all figured out I'm sure.The C and S you spoke about,is it modified for blowthrough?
Guest
Posts: n/a
I do not give up easy and like to do things other don't.
Oh yeah the C & S I got was assembled from the ground up specifically for this application. I had to fill out a two page questionaire about my car so they would know what exactly to do.
Here is a link to it.
https://www.tamparacing.com/forums/s...hreadid=126753
ROTFLMFAO!!!!!!!!!!
I was thinking it was for real too
Any problems with the blow through carb? What about the vent tubes? It doesnt pressureize the innards? I havent seen much about blow through carbs...
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
www.coastaldyno.com
AHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHA
Good shit!!! LOL
Good shit!!! LOL
U.S. Representative Henry Waxman (D-CA)
“If someone is so fearful that they are going to start using their weapons to protect their rights, it makes me very nervous that these people have weapons at all.”
Originally Posted by XYNaPSE
Article I Section 8 gives Congress the power to do whatever Congress deems necessary.
Originally posted by 99Venom
your so busy getting the wrong stuff you even got a 1 bar spring in your wastegate jackass.
Told you he is Scott Millen, Dan's brother.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
