10w40 in the Cobra?
You can use 10-40 it is a little cold for that though, i use 10- 30 it takes 6 quarts, i think ford recomends 5-30 for that car
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
as bitemark stated you do not want to use a heavy weight oil due to the fact that newer engines have much tighter tolerances then your older engines do
"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." --Homer Simpson
Guest
Posts: n/a
Use 10w30. Ford changed to 5w30 becuase it helps with cold emmisions (it's just to thin in my opinion). Just like they changed the rears from 75w90 to 75w140. All the same parts for both but it last longer since people are bad about maintance. Go figure. Although the heavier gear oil has more drag.
