Diablo "Predator"
Diablo "Predator"
Ok since i really don't like the idea of just ordering a set tune.I was thinking about getting one of this things, but i am unsure if it would be any good after i through a set of cams in the car with high compression (11.2.1). are these lil self tuning computer worth the$? here are some option that it comes with.
· Timing Table (+/- 10%)
· Fuel Table (+/- 15%)
· Idle (+/- 20%)
· On/Off switch for Traction Control/Rear 02 Sensors (Off-road Exh)
· Speed Limiter
· Rev Limiter
· Part and Full Throttle Shift Points
· Shift Timing
· Shift Pressure
· Re-Calibrate Speedometer for Gear and Tire Size Changes
It also has Diagnostic Capabilities and Live Data Logging and Monitoring Capabilities.
They say that if a programs not avalable for your combination, that they will custom make one and load it into there web site. then give you a password so that you can DL it into the predator then into your car. so would you buy it? $410.00
· Idle (+/- 20%)
· Speed Limiter
· Rev Limiter
· Shift Timing
· Shift Pressure
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
its not available yet for the GT, should be soon though, i use them on LS1's and 03 Cobras, I also just got the software for the fords to load my own programs into them so i'll no longer have to deal with the programs they use at Diablo.
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
www.coastaldyno.com
so is it only good for minor bolton cars or would it be good down the road when i have the bottom end,heads/cam's and , 175 shot? ok maybe a lil more than a 175
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
its awesome, Sam just did my car and it seems to be holding any boost levels you throw at it so I think it would take your little n2o shot
Proud OIF/OEF Veteran and still serving
They need to make one for the 'scort eheheheh
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
