car is fixed but...
Old Nov 10, 2003 | 05:18 AM
  #17 (permalink)
DrDirt's Avatar
Team Geritol Racing
Look at it while the car is running, if it is wobbling, it's bad. Check the front face. It is made with basically the inner hub and an outer ring. They are joined together with a rubber layer in between them. If the rubber is squeezing/oozing out, it is bad. P\Pull the spout and put a timing light on it and see what the timing reads. If it reads something stupid like say 10^ plus or minus 10, it has slipped and is bad.
YO! Barry! You LOST!
Old Nov 10, 2003 | 05:41 AM
  #18 (permalink)
TheShow50h's Avatar
The little 5.0 that could
my balancer was reading 16 degrees before i had it changed, then it read 22 :O Tuned it back down to 14 and that was the straw that broke the camels back when it came to traction.
-Vince
Old Nov 10, 2003 | 11:37 AM
  #19 (permalink)
Strokd85's Avatar
Daddy-O
what weight Balancer would you need (28oz/50oz)?
I've got a 28oz balancer that I can sell to you if that will work.
SFI rated..
I am your penalty.....
