Saw a sad ordeal tonight at BMP
TR Balla Donor Supreme
on
An older man brought out his 04 cobra and could only muster a best of Mid 13s at 103-104. It was a sweet looking ride and he sounded like he was shifting with a purpose, but I don't know. I just thought they had better top end than that.
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
he must have some issues with driving technique
Maybe he had less than 500 miles on it?
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
on
Never even thought of that....I guess I can rest easier knowing that could be it.
Bro there are so many slow ass 03 cobras around it isn't funny.there isn't a week that I don't see a 03 cobra in the mid 13's .they should make a show "when bad drivers get fast car" or somthing.
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
haaaaaa,get a Honda,yeah so he could go even slower!!LOL
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
