Sudo-Dilema
Old Oct 30, 2003 | 09:42 AM
Alan's Avatar
drives euro trash
Default Sudo-Dilema
Do I spend the money on a ported head now...or should I wait until after I get a turbo? I have my new/used FR intake manifold sitting on my office floor, and it would be a great opportunity to have it port matched to the head prior to install.
Installation of a head will be a bit easier now without all the plumbing running about the engine compartment. But if my motor gives up the ghost, I don't want to risk ruining my head.
On the other hand, MM&FF got 360 fwhp out of the stock internals. When they broke down the old motor they found the internals were as cherry as if the motor were brand new off the showroom floor. So it seems the risk of throwing a rod through the block isn't as high as long as tuning is dead-on.
So what should I do?
Discuss and help Alan make up his mind.
Old Oct 30, 2003 | 04:22 PM
351coupe's Avatar
refinish artist
Get the prorting done befor the turbo,if not you'll have to tear it all back down to do it.Just my opinion.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
Old Oct 31, 2003 | 07:05 AM
Alan's Avatar
drives euro trash
Originally posted by Force Fed 23
Seriously. If you've got the stuff now, do it so you'll get some practice getting it tuned before throwing the turbo on.
I definately see your point. So would it also be beneficial to tune the car with the larger injectors and chip prior to getting the blurbo as well? Then once the turbo is installed all it would take is some fine tuning of the chip to get things right. I'm thinking 48lb injectors should work nicely with where I want to be in the first stage of the blurbo project. I'd love to go with a used Pectel being sold for $1500 (with wiring harness and base mapping programs), but despite that being one heck of a deal, that is alot of money to fork out.
I really want to set my limit at about 250-300 fwhp and hope my clutch hangs in there. I know I should (should being the key word) upgrade the clutch and get a Quaife before I up the power, but that means me taking a day or two off from work and driving up to North Carolina to the only shop that can properly install/shim the differential in my tranny.
