tires rubbing on coil-overs!
Is anybody else running a 18x9.5" wheel with coil-overs and having problems with the tire hitting the springs??? This problem has been going on for a while. It was originally a clunk sound like a spring binding and letting go, now if i'm backing out of a parking spot it's horrible. I finally had someone drive the car back and forth while i hung off the side of the car.
with the car sitting still and the wheels straight, there is about 1/4" clearance, and when the wheels are at full lock, there is about 1/8". my question, why would this change? if the strut is attached at the spindle, i would think that there should be no change in distance between the c/o and the wheel as they would move relative to each other.
anybody have any idea why this would be happening??
can i put a spacer on the front??
the wheels are 2000 Cobra R 18x9.5's with 255/45R18 Bridgestone s-03 pole position tires.
Thanks for any help!!
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Dave
Originally posted by Mars_302
Id get some longer studs too if you are gonna use a spacer. Btw
How do you like those So3s?
I still dont know why the distance between the coil-over and the tire would change
. since the strut is bolted to the spindle and the turning pivot of the wheel is at the top of the strut, the measurement should always be the same!!! Ugh...
Dave
Dave
