Pushrod questions for the pushrod dummy...
Guest
Posts: n/a
You can get 350hp out of a stock bottom end motor. So start with a bone stock motor, then you can put a cam in it, a GOOD set of aluminum heads (needed since you won't have high compression to make power), carbed intake and a Holley.
Something to consider is will a Windsor even fit under the hood of one of those Daytona coupes? Its got a pretty low hoodline.
I have a friend that plays around with stock bottom end 5.0"s.The one in his daily driver is cast everything bottom end with windsor d 303 heads poted a tad also an f or x cam.This was a carb 650 btw runs with a 5 sp in an 85 stang 8.4's at sunshine with me in the car lossing traction a lil.Btw his car has ponie rims for the turns the thing has a great rpm rang in turns
.ps ask goop about him
his son has the 88 shrt block 140thou mile motor in his race car without the nos he ran 7.04 i think not to bad out of a stock 302
lemme know if you are intrested about some of his set ups
Note the engine placement in relation to the suspension. Eight Webers ought to be easy to tune!
Nice looking car. Always wanted to do something like this.
Look around. Factory 5 makes the most user friendly kit, but there are plenty of others out there. Make sure you do a LOT of research before committing to a project like this. The guy with the Everett Morrison kit took about 5 years to finish his. It was beautiful, but 5 years of time is a killer investment.
Beer. Now there's a temporary solution. --Homer Simpson
http://ourworld.compuserve.com/homepages/427cobra/
BULLETIN: PRICE REDUCTION!!!
Upstate Super Replicars, Inc. has reduced the price on all Component packages for their Upstate Daytona Coupe Cobra replica, plus added the capability of utilizing a Big Block Ford FE V-8!
Body Frame package starting at $19,999.00
It'll take a big block.
