Calculate Your E.T., H.P., Etc. Here
Guest
Posts: n/a
peak 227
avg 257
ET your car is capable of: 14.07
MPH your car is capable of: 96
Total fuel consumption under wide open throttle: 140 lbs/hr
Minimum fuel pump volume required: 84 L/hr
Optimum fuel pump volume required: 100 L/hr
Injector size needed at stock pressure (40 psi): 20 lb/hr
Pressure required on current injectors to simulate needed size: 28 PSI
FMU Required on Current Injectors: N/A
Your current injector status is: OVER INJECTED
avg 257
ET CALCULATOR RESULTS
ET your car is capable of: 11.92
MPH your car is capable of: 114
Given ideal conditions, this is roughly the elapsed time (ET) and mile per hour (MPH) your Mustang could run.
ET your car is capable of: 9.83
MPH your car is capable of: 138
Thats if I could get traction and drive the damn thing
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Peak Horsepower: 286
Average Horsepower: 266
but i made 228 rwhp
ET your car is capable of: 14.02
MPH your car is capable of: 97
but i did 12.9
Your quarter mile ET would be: 12.80
Your quarter mile MPH would be: 103.92
not 2 bad there
but i made 228 rwhp
but i did 12.9
not 2 bad there
Yeah it's broken
-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-FR Aluminum drive shaft
-Steeda G-trac bar
-Kenny Brown sub frames
-UPR shifter
-Spec clutch
-Spec Alumn Flywheel
-Steeda Clutch quadrant
-Steeda fire wall adj
-4:10 gear
-Mac upper adj control arms
-Mac Lower control arms
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
Yeah it's broken-Cobra block
-Cobra crank
-Diamond pistons
-Eagle rods
-NOSzle Kit
-Bottle Heater
-QA1 K-Member
-D&D Tubular A-arms
-D&D Coil overs
-1/2' Intake spacer
-Windage tray
-80MM C&L
-K&N Filter
-Steeda G-trac bar
-UPR shifter
-Spec clutch
-4:10 gear
-Mac T/A girdle
-Steeda quad shocks
-Hooker long tubes
-DR.Gas X-pipe
ET your car is capable of: 12.03
MPH your car is capable of: 113
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
