quick question
Old Jul 31, 2003 | 06:38 PM
Slug's Avatar
Default quick question
What is the biggest size tire I can put on the rear of my car? Right now I have 245/45/17's. Thanks.
Joe
Old Jul 31, 2003 | 06:41 PM
Alan's Avatar
drives euro trash
Depends on the width of your wheels. The stock 17's are 8 or 8.5 inches wide. The widest profile tire you can really fit on there is a 285.
If you go up to a 17x9 (like the Cobra R), you can fit up to a 315 on the rear without rubbing anything.
Old Jul 31, 2003 | 07:57 PM
Slug's Avatar
Thanks! I was thinking of 275/40's on the rear and leaving the fronts the same way they already are. By the way, I see your car sometimes on my way to and from work. At least I think it's your car I see. Thanks again.
Joe
Old Jul 31, 2003 | 08:17 PM
StuntMan's Avatar
Driver
I have seen a 315 on stock Cobra rim(doesnt look right). I have 31535r17 on mine I rarely ever rub and I am lowered 1.5in. could probally go wider if I took out the quads and tail pipes. 275/40's will fit with no problem.
If speed kills then I'm suicidal
Old Aug 1, 2003 | 08:07 PM
Slug's Avatar
Thanks, Stuntman.
Joe
Old Aug 2, 2003 | 07:31 PM
superdave's Avatar
I think the size vs. rubbing issue has been addressed, sooo....
If you know the width of your tire, most tire manufactures will give a range of rim widths that their particular size of tire will fit (in other words, a Bridgestone 275W tire might fit an 8" rim, but a Nitto 275W might not). They also give a recommended rim width somewhere within that range that would best fit the tire.
Check with the manufacturers before you buy, most of them will list it on their sites, or tirerack.com usually has that info listed as well.
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
