ford rotors...
Old Jul 26, 2003 | 10:01 AM
m0nk3y's Avatar
pwns.
Default ford rotors...
On an escort, is there a trick to getting the rotors off? one of them is rusted on and is soaking in PB now, but the other was pretty loose.... Is there something other than a little rust holding it on? the assembly screws are gone, and it wiggles freely, but wont move more than 1/4" from the base of the hub. thanks!
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Jul 26, 2003 | 12:58 PM
Young,Fablous,&Broke's Avatar
BFH....
Try a cartoon hammer, you know, the rubber mallet.
Old Jul 26, 2003 | 05:35 PM
superdave's Avatar
Default Re: ford rotors...
check where the studs go through the rotor, sometimes there are little retaining clips that hold it together.
Dave
1998 GT cp (totalled, compliments of a dump truck)
1996 pony (awaiting transplant)
Old Jul 27, 2003 | 01:45 AM
craig_302's Avatar
boostmonkey
1. remove clips
2. BFH
Alot of the times, if you do not plan on reusing the rotors, just nail it with a BFmetalH. They require it at times.
To prevent the headache from happening again, I brushed the rust off of the hub area with a wire brush and gave it an uber thin coat of wheel bearing grease. Be careful here, too much grease will sling up onto the pads/rotors and make it very difficult to stop. Hope that helps you in time.
Old Jul 27, 2003 | 06:03 AM
m0nk3y's Avatar
pwns.
yup, iy was a ring of rust. we let it sit with pb all over it multiple times, then leonard went at it with a metal hammer for a little bit, and they came off... COATED in salty rust. now, for the calipers... replacing them, theyre so rusted over, and I dont want to push those rusty pistons back.
Old Jul 27, 2003 | 06:34 AM
herrcomestrouble's Avatar
1 word.. NEVER SEIZE!! ... er.. ok that was 2.. but you get the idea
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Jul 27, 2003 | 07:01 AM
m0nk3y's Avatar
pwns.
you mean... anti-seize?
