Drag Racing Don't like turns? Tech talk about drag racing and drag event discussions here
need launching help....
Old Jun 30, 2006 | 08:06 AM
BLUE2KSS's Avatar
Mechanical Engineer
Originally Posted by geoff
im on street tires and i was wandering what to launch on the street. im not used to this type of clutch so. my tires dont spin. my boy launched the car at like 6500rpms and got a bad ass launch. im wandering if i should fether the clutch or instead of just dumping it and giving it full throttle if i should feather the gas pedal. lmk
the only way you will figure it out is to do it
go out and have fun, just do it away from everyone so you dont get busted
good luck
Old Jun 30, 2006 | 10:44 AM
Hybrid_Ej1's Avatar
5th ej1 one in the making
call me john....
EJ Crew Member #2
Old Jun 30, 2006 | 07:31 PM
BDIX's Avatar
Dick is Huge!
Originally Posted by Jaso0on
Go get some slicks, put them on, hold gas down at idle until it nails the limiter, remove your foot from the clutch, watch car stall
Then, learn to drive..
yo dude.. those hondas are sketchy
I cant figure them out
Totalled his shit!@
Old Jul 4, 2006 | 05:57 AM
T4eg's Avatar
Originally Posted by SmokinS13SR20
Pre-Loading. When you reach the first staging light, and pull up the e-brake, than you proceed to slip the clutch to move up to trigger the next light. Which in turn keeps your drivetrain on each other so the gears dont smash into each other. You then put the ebrake down and slip the clutch off the line at like 5-6k Let the clutch out as much as possible without spinning. If it spins dont take the clutch out to much. This will eat your clutch but is probably the best way to launch.
I figured I would post someone worth while.
good explaination ....Preloading will save ur axles and tranny just harder on clutch like stated above
Old Jul 4, 2006 | 05:31 PM
TurboJdmEk's Avatar
is on blocks...
Originally Posted by oemcivic0888
call me john....
you talking to me???? who is this
its coming...
Old Jul 5, 2006 | 11:53 AM
  #17 (permalink)
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
i launch at about 2500 at sunshine and just pedal it out til needed
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Jul 5, 2006 | 04:30 PM
  #18 (permalink)
95w_bTEG's Avatar
!!PORTUGAL!!
launch control!! thats what i got, and some sticky tires.
Old Jul 10, 2006 | 04:47 PM
  #19 (permalink)
BugofDoom's Avatar
Rev it up to 6500rpm then dump the clutch and watch everyone laugh at you when you snap your axles. Then put Bob's cock in your mouth and procede to suck until he blows his load in your mouth and you should run a low 12 because hondas are wicked fast when they are naturally aspirated.
Old Jul 10, 2006 | 07:38 PM
  #20 (permalink)
Ray's Avatar
Ray
Befürchten Sie Meinen Zor
dude, not to be a dick but,
"i'm not used to it"
that's the key. no one is ever used to how something new is on their car. everyone has to start in the beginning for everything. just drive the car enough to where you do get used to it, then take it to the track, cause taking it to the track without being used to how it drives, chances are, you'll break something.
Vincent Mancini : Don Lucchesi, you are a man of finance and politics. These things I don't understand.
Don Lucchesi : You understand guns?
Vincent Mancini: Yes.
Don Lucchesi: Finance is a gun. Politics is knowing when to pull the trigger.
