Does anyone know about
Old Mar 19, 2003 | 05:19 PM
CrazyMoparGirl's Avatar
Guest
they are the same as a 5.2 V8 minus 2 cylinders
Old Mar 19, 2003 | 07:50 PM
Guest
Small blocks have that strange aluminum water pump/front piece that uses a gasket. O have blown an intake gasket on the water xover and it hydro locked the block, #1 was full of water,shot about 10ft in the air when I took the spark plug out and turned the engine over by hand.
Old Mar 19, 2003 | 09:30 PM
Guest
Stupid Type O get over it sheesh
Old Mar 20, 2003 | 10:07 AM
Guest
Possible, I would go ahead and replace the intake and both head gaskets, just in case that way you only ripp the top end open once. If it still has water in the oil then it's the front aluminum peice that is leaking.
Old Mar 20, 2003 | 02:01 PM
Guest
That's the best idea yet from you
