I purchased the unlimited data plan when I first got my car, hotspot is on, uconnect
Originally Posted by Ricky Castleberry
I purchased the unlimited data plan when I first got my car, hotspot is on, uconnect connected services and my Dodge dealer don't know what to do, uconnect transferred me to AT&T, they said they were the wrong ones to talk to, so I'm back to square one. Going to try Google Hangouts to make WiFi calls
Ok, gotcha. So it sounds like it's on and activated, but your unable to use it? I've not used this feature, but I've heard it is similar to connecting to a wifi router. Are you able to see anything called Uconnect or something similar while searching for a wifi signal in your phone?
If there is a problem, I suspect you would need to contact Uconnect directly. This excerpt was copied from their site:
TURN YOUR VEHICLE INTO AN UNLIMITED 3G WI-FI HOTSPOT
Don’t waste your precious data. Add an available 3G Wi-Fi Hotspot subscription( Disclosure15)*to your trial or package to get Wi-Fi and 3G connectivity on demand. You can make your purchase from the Uconnect*Store( Disclosure16)*on your touchscreen or at Mopar*Owner Connect. Just make sure you’ve registered for available Uconnect Access( Disclosure1)and have set up a Uconnect Payment PIN. After you’ve made your purchase, turn on your signal and connect your devices. With a 3G Wi-Fi Hotspot, your passengers can shop, surf the web, check emails and stay connected wirelessly on their personal devices.
3G Wi-Fi Hotspot Subscriptions (Extra Charges Apply):
$9.99/Day, $19.99/Week, $49.99/Month.
I've dealt with Uconnect customer service in the past on a couple of vehicles. To say it bluntly, they are not very helpful. They read from a script which is fine, and normal for a call center. But it usually takes multiple calls to get the problem fixed. Mostly because they've hang up on me a few times because they don't know how to forward a call.
I hope you get it sorted out before having to call them, and if you do, I really hope you don't have the same experience with them.
Bullitt 3309
02-03-2003 09:12 AM
