experience with closed box CAI like the LMI box?
Old Mar 27, 2019 | 08:21 AM
Default experience with closed box CAI like the LMI box?
ScatPack702Junior Member
Join Date: Mar 2019Posts: 7Feedback Score: 0 reviewsThat’s exactly what I’m seeing on all YouTube videos. They usually say to get the hellcat filter, hellcat lower box, and the tube that reaches out to the snorkel in the grill (Scat Packs have the snorkels in grill). I’ve read enough as well about all the different kinds of CAI. I was wondering if anyone had experience with closed box CAI like the LMI box or anything.
Old Mar 27, 2019 | 08:22 AM
The scat packs have the opening in the grill, but there is a shield that goes beside the radiator that on the scat pack is closed off. For the hellcat it has an opening. That also needs to be replaced. The link provided above has the radiator shield, the duct/tube and the lower air box. All you would then need is the hellcat air filter.Attached Thumbnails
Old Mar 27, 2019 | 08:29 AM
Instead of buying a new piece, I bet I could do a pretty good job
of neatly copying that opening as to location and size...
I like it that Dodge also has the plastic part to get you started
toward brake ducts, if you do road course track days.
Old Mar 27, 2019 | 08:35 AM
Default What caliper paint did you go with? Just plain old stuff from AutoZone: I painted it
What caliper paint did you go with?Just plain old stuff from AutoZone: I painted it with the kit and then let it sit for 3 days (takes forever to dry thoroughly) then top coated it with the VHT spray.
https://www.autozone.com/paint-and-b...kit/539677_0_0
https://www.autozone.com/paint-and-b...int/419005_0_0
I would skip the kit and just use the spray, but the caliper has to be VERY clean first.
Oct 27, 2016 10:24 AM
Audio HQ
Nov 19, 2014 09:36 PM
