ooling fan, 2006 charger rt Diablo i3 cant find my vin
Old Feb 3, 2019 | 09:42 PM
Default ooling fan, 2006 charger rt Diablo i3 cant find my vin
Konner Tolan
Junior Member
2006 charger rt Diablo i3 cant find my vinYesterday I went to change my fan settings and my device says I'm out of licenses. I checked and the tuner says its married to my car but I cant find the vin. It worked fine a week ago but now the car seems to have forgotten the tune because the dash is lit up and my car tries to die after accel. It Is cammed along with a few other things so its undriveable now. It was neg 61 the past 3 days leading up to this but it's in storage during the winter.
Old Feb 3, 2019 | 09:43 PM
djalbin
Senior Member
Call the DiabloSport help desk. Since they're closed for the weekend you can look to see if there are any software updates for the i3. If there's any updates, download/install them and then reconnect the i3 to your car. No guarantee but sometimes the updates fix the problem.
Old Feb 3, 2019 | 09:45 PM
2006?
If I needed a cooling fan, I would wire it through a fuse from an under hood 12v connection, route the wires parallel to factory wiring,
and send it to a manually operated cut off switch for when I'm working on the car.
That way the fan comes on when *I* want it to, and no computer required.
There are manually adjustable t-stats, if I need the fan to come on based on temps,
in case the factory t-$tat/$ensor is not working. Once set, the adjustable t-stat will always
come on at the set temp. I place it next to the radiator, instead in the radiator hose.
There are work-arounds each time something fails because of stuff that was added to the car...in this case Diablosport,
which may be a $300 item.
What state are you in, Konner?
Chassis & Suspension Tech
Dec 28, 2018 04:39 PM
Jul 31, 2018 12:29 AM
Jul 31, 2018 12:12 AM
Jun 14, 2018 09:34 PM
Jun 14, 2018 09:10 PM
