Pursuit model suspension thread
Quote:Originally Posted by GertFrobe
With the OE springs and the OE Sachs struts and Nivomat shocks on it, the ride height was 30" in front and 31" in back (measured from ground up through center caps to bottom of wheel wells).
After installing the Mopar Stage 1 springs, the ride heights were 29" and 30" for front/back ride height; so I got the 1" drop I expected with the spring replacement. However, the OE struts and shocks were shot. They rode terribly, jarring my kidneys and teeth with every bump. Highway expansion joints on overpasses were intolerable at highway speeds. So I set about looking for (affordable) replacements for the shocks/struts.
I settled on the Monroe HD Magnums since they seemed to be up to the task for handling the heavy car (they are actually meant for light trucks/SUVs from what I read), plus they were in my price range. So I got a set and installed them.
After replacing OE shocks and struts with the Monroe HD Magnums, ride heights were 28" and 29" in the front and back respectively. That was quite a surprise since I had always thought the springs alone determined ride height, and the shocks/struts would not affect it. That does not seems to be the case with these cars...at least it isn't with mine.
After almost 10K miles, the ride height has dropped a little further, now riding between 27-28" in the front and between 28-29" in the rear. I attribute this to the Monroe shocks/struts wearing out. I can feel them getting rougher, and I'm guessing the lowered operating range is too far outside their intended operation zone, which is causing them to wear at an accelerated rate. Here again, I would not think that would contribute to the further lowering of ride height, but given that their installation alone seemed to affect it, I guess I cannot rule out their impending end-of-life affecting it here.
I would have liked to installed the Bilstein shocks and struts with the springs originally, but I was having trouble finding any place that had the struts in stock. Not to mention their price was a little out of my range at the time. In hindsight, I should have just bitten the bullet and found them where ever I needed to and paid what I needed to pay to get them for the car. I have no doubt they would be better suited to the lowered ride height, not to mention I suspect they wouldn't have contributed to the extra lowering effects beyond the 1" the Stage 1s were supposed to provide.
All in all, I'm satisfied with the Stage 1s but not pleased with the extra lowering since installing the Monroe components. I could have done with 1", and would have been fine with up to 2", but the 2.5" drop is getting worrisome. I haven't met a corner yet I can't take at twice the posted speed, sure, but any pot holes of significant size will really jar the car. I think I'm lucky I'm still riding on the 18" rims and tires right now, lest I have bent a rim by now on some of the larger pot holes I've accidentally run across in the last couple of months.
On my 2018 Charger, the ground up to fender lip is 30" from the ground.
I have P215/65/R17 Michelins and 17" x 7" wheels that were on the car new.
Front springs are black with red tags on them. Haven't looked at the back yet.
I'm wondering if I just lucked out.
I haven't looked closely under the car, but I thought about lowering the front (and also the rear) by another 1"without reaching the 28" that you mentioned. I need to find some adjustable control arms front and rear before lowering it.
Any adjustable control arm suggestions?
I like the smaller wheels since they lower the car. Bigger diameter rims interfere with lowering.
I don't mind that people want the "look" of "filling up the wheelwells", but I want good cornering
with a lower car instead.
Quote:Originally Posted by senor dodgeOn my 2018 Charger, the ground up to fender lip is 30" from the ground.
Quote:Originally Posted by senor dodgeI have P215/65/R17 Michelins and 17" x 7" wheels that were on the car new.
I dislike the look of these cars when they have a large gap between the top of the tires and the bottom of the fender well, regardless of the rim size. But once that is dealt with, the look of the wheels and tires on the car is a more nuanced thing for me. I used to not care about what size the rims were, but over time I find myself noticing more and more when an LX with < 20" rims drives by. There is something about the amount of tire that I can see that just draws my eye to them, and that's disconcerting since I have 18" wheels and tires on mine (always have, across 2 Challengers and this Charger).
It's hard to explain, and it's definitely a personal preference thing, but I find now that the look of a 20" rim and tire on these cars is less noticeable when admiring them from afar, and that's basically what I'm looking for (eventually) with mine.
Quote:Originally Posted by senor dodgeFront springs are black with red tags on them. Haven't looked at the back yet.
Quote:Originally Posted by senor dodgeI'm wondering if I just lucked out.
The Stage 1s I installed on mine are supposed to only drop an inch, and they did just that at first, but once I started in with the el-cheapo struts and shocks, things got muddled and the ride height dropped further than the promised inch. I do think mine is an edge case though, and the Mopar Stage 1s will not normally drop your car more than an inch in most any other circumstances. There are lots of people that have installed them, and I have never heard anyone complain about them, so they are a solid option for a suspension mod IMHO.
Quote:Originally Posted by senor dodgeI need to find some adjustable control arms front and rear before lowering it.
Now, that assumes the car's original ride height was not already lower than normal (like an SRT or something), and it also assumes that the person doing the alignment is competent and willing to think outside the box when trying to effect the alignment on the car. In other words, even a modest 1" drop could cause your average Firestone or City Garage alignment tech to refuse service saying, "it's way out of spec and there is not enough adjustment room to get it into spec!" But if you have a relationship with the local Dodge house, and their alignment tech is willing to get your car aligned by any means necessary before requiring you to buy more parts, then that same 1" drop could be dealt with by using the alignment specs from an SRT model of the same year, and in some rare cases the engine cradle and/or rear cradle might have to be moved slightly to one side or the other too.
In terms of personal experience, I can offer this:
- on a previous LX (2011 Challenger) that I lowered an inch in the front and an inch and a half in the rear, I was able to get it aligned without any extra hardware. We had to use the SRT specs to do it, but that's it.
- my current situation will probably require some extra hardware at some point, but I have not purchased or installed any just yet. I am not nearly done pulling it apart (especially the struts) and putting it back together, so I figured I would wait to deal with the alignment stuff until I was done taking the front end apart and replacing things. Otherwise I would just have to keep taking it back for another alignment after I got done replacing whatever.
- even though my extreme drop in ride height has thrown off the alignment, it is not so bad that I cannot deal with it for now. I just drove to Atlanta and back on the same tires that the car had when I got it several months ago, and they were definitely worn down from the trip, but they weren't ruined or anything from abnormal wear from the mal-aligned front end.
This is all anecdotal evidence, yes, so please take it for what it's worth as related to any of your future situations.
Quote:Originally Posted by senor dodgeAny adjustable control arm suggestions?
Quote:Originally Posted by senor dodgeI like the smaller wheels since they lower the car. Bigger diameter rims interfere with lowering.
And with that, I must bid you Mountain Dew. I was supposed to start working on work stuff about 30 minutes ago, yet I'm still on this blasted forum! I swear, if I could just find someone to pay me to hang out on this one and the handful of others I belong to, I would be the best employ in the world!! I would be early every day, leave late, never take vacations, and probably truly try my hardest to get promotions!
Oh well, a man can dream, can't he?!?!
Quote:Originally Posted by senor dodgeThanks for the good advice.
I want adjustable arms because I don't want some tech messing with the offset washers
that I presume the car has for stock alignment.
I would maybe do the alignment before
I take it in.......and I would ask the dealer to just check and verify it.
I have found with other cars that they can be lowered to where the control arms and/or axles
are horizontal, and it is still within the alignment tolerance. Then sometimes only the toe needs to be set.
I haven't heard of many people doing it in the last few years, but that was all the rage back in 2010-2012 I would say. I even caught the fever and did it to my 2011 Challenger. I was very pleased with the results, I recommend it to anyone looking to lower their LX without going too low (and they don't already have an SRT obviously).
You can probably expect a little over an inch in the rear but right at or a little less than an inch in the front if you were to do this mod. That sounds like what you were looking for instead of the more pronounced drops that the aftermarket springs will get you.
Anyway, just some food for thought. Cheers!
Chassis & Suspension Tech
12-17-2018 08:30 PM
4
12-01-2018 08:40 PM
09-01-2018 12:22 AM
07-23-2018 03:15 PM
