DIY How to Audio - Alarms - Navigation - Electronics
How to install REC navigation
https://www.chargerforums.com/forums/...24&postcount=3
How to install MyGig in 2006-2007 Models
https://www.chargerforums.com/forums/...ad.php?t=87969
UConnect phone pairing guide (2009+)
http://chrysler.servigistics.com/dodge/en/uconnect/
Installing Lockpick in 2011-2014
https://www.chargerforums.com/forums/...d.php?t=149705 --- PDF
Installing carputer in 2011-2014
https://www.chargerforums.com/forums/...d.php?t=164384
Changing color of UConnect in 2011-2014
https://www.chargerforums.com/forums/...d.php?t=158708
Upgrade MyGig Hard Drive
https://www.chargerforums.com/forums/...ad.php?t=82946
https://www.chargerforums.com/forums/...d.php?t=109886
Dealer (info/diagnostics) mode on uConnect 8.4 (2011+)
https://www.chargerforums.com/forums/...d.php?t=226977
How to fix NAV disc errors
https://www.chargerforums.com/forums/...ad.php?t=91694
How to recover from bad REC navigation flash
https://www.chargerforums.com/forums/...d.php?t=140838
How to replace single disk CD player/stereo with double-din unit
https://www.chargerforums.com/forums/...ad.php?t=44189
Connecting aftermarket stereo
https://www.chargerforums.com/forums/...ad.php?t=30930
Installating aftermarket amp
https://www.chargerforums.com/forums/...ead.php?t=9821
iPod Dock in ash tray
https://www.chargerforums.com/forums/...d.php?t=105807
Replacing stereo speakers
https://www.chargerforums.com/forums/...ad.php?t=79111 --- PDF
Installing Dash speakers (2008-2010)
https://www.chargerforums.com/forums/...d.php?t=144544 --- PDF
Kicker Tweeter install (in dash)
https://www.chargerforums.com/forums/...d.php?t=298833
MOPAR Kicker Sub install
https://www.chargerforums.com/forums/...d.php?t=103964 --- PDF
Installing 8" Sub and amp
https://www.chargerforums.com/forums/...ad.php?t=81444 --- PDF
REC Nav joystick replacement
Step by Step (by Step by Step) Guide on Nav Joystick Replacement
REC Nav disassembly to clean laser lens
Rec Nav Laser Eye Cleaning (nav disk error) --- PDF
MyGig RER LCD Replacement
https://www.chargerforums.com/forums/...d.php?t=142944
Adding Factory U-connect (2006-2007)
https://www.chargerforums.com/forums/...&postcount=174
HomeLink installation
Homelink Install Walkthrough --- PDF
http://www.challengertalk.com/forums...63/#post178901
Hardwiring Radar Detector
https://www.chargerforums.com/forums/...ead.php?t=8571
https://www.chargerforums.com/forums/...d.php?t=106284 - using uConnect Mirror for power
iPOD Interface
https://www.chargerforums.com/forums/...ad.php?t=30079
Connecting your iPhone to UConnect
https://www.chargerforums.com/forums/...d.php?t=156565
Adding Aux/iPOD to REC/NAV system
https://www.chargerforums.com/forums/...d.php?t=137177
iPad Installation on Ram-Mount (Police package Charger)
https://www.chargerforums.com/forums/...d.php?t=157748
Changing sort order of iPhone/iPod songs (2011-2014)
https://www.chargerforums.com/forums/...d.php?t=163621
Add video-out feed from VES
Video out from factory VES system
Lockpick and Camera Install
https://www.chargerforums.com/forums/...d.php?t=125941
iPOD Interface
part 2
Xm Roady 2 installation in sunglasses holder
https://www.chargerforums.com/forums/...ad.php?t=45486
Siruis Sportser 4/5 in sunglasses holder
https://www.chargerforums.com/forums/...d.php?t=125973
Replacing headlight switch (automatic headlights)
https://www.chargerforums.com/forums/...ead.php?t=3428
Installing Paddle Shifters
How to install the AMG Shift Paddles on our LX's --- PDF
Direct Wired Paddle Shifters --- PDF
Paddle Shifter Wiring Harness Install - Step by Step --- PDF - Paddle Shifter Wiring Harness Install
Paddle Shifter Install - Paddles and Steering Wheel Connections --- PDF - Installing the paddles
How to install Paddle Shift on the 2008 models --- PDF - 2008-2014
http://www.lxforums.com/board/f58/ne...2010-a-271612/ --- PDF- Easy wiring, using TranZformer
Replacing Keyfob Battery
https://www.chargerforums.com/forums/...ad.php?t=81685
https://www.chargerforums.com/forums/...d.php?t=137061
Replacement transponder key (without remote)
https://www.chargerforums.com/forums/...d.php?t=109510
Adding Keyless-Go (2008+)
https://www.chargerforums.com/forums/...d.php?t=121956
Antenna mod for 08's
https://www.chargerforums.com/forums/....php?p=1382773
Shark Fin Antenna Mod
https://www.chargerforums.com/forums/...d.php?t=124894
Adjust Outside Temp displayed in EVIC
https://www.chargerforums.com/forums/...ad.php?t=74439
PLX OBDII Mirror Gauge
https://www.chargerforums.com/forums/....php?p=1576087
Relocating the OBDII Port
Relocate OBD II port?
GPS Display in sunglasses holder
https://www.chargerforums.com/forums/...d.php?t=102323
Switches in center bezel + aux fuse box
https://www.chargerforums.com/forums/...d.php?t=106253
Dash Gauge Pod
https://www.chargerforums.com/forums/....php?p=1759951
Removing instrument cluster (and installing lit gauge kit)
http://www.lxforums.com/board/f58/%2...x-cars-291184/
Installing Backup Sensors
https://www.chargerforums.com/forums/...d.php?t=109278
Installing Backup camera in trunk lock
https://www.chargerforums.com/forums/...d.php?t=119726
https://www.chargerforums.com/forums/...d.php?t=132052
Installing backup camera in license plate light
https://www.chargerforums.com/forums/...d.php?t=152477 (2006-2007)
https://www.chargerforums.com/forums/...&postcount=111 (2008-2010, includes center console removal instructions) --- PDF
Adding EVIC/steering wheel controls
https://www.chargerforums.com/forums/...d.php?t=230473 -- SE/SXT 2006-2010
http://www.challengertalk.com/forums...tml#post303130
http://www.lxforums.com/board/f74/ad...itches-279059/
Battery replacement
https://www.chargerforums.com/forums/...d.php?t=230729
Dash camera selection and installation ideas
https://www.chargerforums.com/forums/...d.php?t=239442
Dash Gauge Pod
Battery replacement
