DIY How to list PERFORMANCE / ENGINE
Popular mods, including intake air temperature (IAT) sensor
Performance impact of popular engine mods - must-read --- PDF
http://www.challengertalk.com/forums...r-solved-63343
https://www.chargerforums.com/forums/...d.php?t=216873
https://www.chargerforums.com/forums/...ad.php?t=94998
Performance 101
https://www.chargerforums.com/forums/...ad.php?t=56465
Timing, it's ALL about the timing !
http://www.diablosport.com/index.php...wtopic&t=15386
Drive Cycles - prerequisite to getting smogged
http://www.lxforums.com/board/f74/wh...cycles-201914/
http://www.lxforums.com/board/f225/e...w-pass-279097/
http://img.neons.org/archives/chrysler_drive_cycle.pdf
Understanding Gas, Octane, Knock, Detonation, Fuel additives
https://www.chargerforums.com/forums/...d.php?t=136598
Chassis Dyno Testing Explained
The Comprehensive V6 Performance Thread
https://www.chargerforums.com/forums/...d.php?t=122930
X E Ryder's Diablosport Predator Knowledgebase (U7135 - HEMI)
https://www.chargerforums.com/forums/...ad.php?t=57133
Adjusting Predator tunes
https://www.chargerforums.com/forums/...d.php?t=139290
Backing up tunes and loading custom tunes on Predator
https://www.chargerforums.com/forums/...d.php?t=135811
Updating your Predator, Software and Drivers
https://www.chargerforums.com/forums/...d.php?t=135810
Data logging with Diablosport Predator
https://www.chargerforums.com/forums/...ad.php?t=65274
https://www.chargerforums.com/forums/...d.php?t=155038
https://www.chargerforums.com/forums/...d.php?t=155047
Links to Diablosport Predator CROMs
https://www.chargerforums.com/forums/...d.php?t=123323
Diablosport CMR Tuning Options List
https://www.chargerforums.com/forums/...ad.php?t=57532
PIDs to log
https://www.chargerforums.com/forums/...d.php?t=125705
DashHawk Graphing Walkthrough
robagd.com
Installing Innovate Wideband
How to properly install an Innovate Motorsport LC-1 Wideband
Automatic Transmission Info
https://www.chargerforums.com/forums/...ad.php?t=74653
CAI Installation walkthrough
https://www.chargerforums.com/forums/...ad.php?t=72017
Installing Mopar CAI
https://www.chargerforums.com/forums/...ad.php?t=55951
Installing AEM Bruteforce CAI
http://office-docs.com/CAIInstall/Page1.htm
Custom Twin Ram Air Intake
https://www.chargerforums.com/forums/...ad.php?t=35832
Chilly Air Intake Mod
X E Ryder's Chilly Air Intake Mod --- PDF
Modified Stock Intake box
https://www.chargerforums.com/forums/...d.php?t=106324 --- PDF
Homemade CAI
https://www.chargerforums.com/forums/...d.php?t=127769
How to port a V6 Throttle body
https://www.chargerforums.com/forums/...d.php?t=100772
All you need to know about Oil Catch Cans
https://www.chargerforums.com/forums/...d.php?t=106028
Replacing Spark Plugs
https://www.chargerforums.com/forums/...9&postcount=52 (5.7L)
https://www.chargerforums.com/forums/...d.php?t=154044 (2.7L) --- PDF
Indexing Spark Plugs
https://www.chargerforums.com/forums/...ad.php?t=66961
Removing air intake plenum from 3.5L V6
http://www.custommagnums.com/forums/...m-removal.html --- PDF
Removing intake manifold from 3.6L V6 (2011+)
https://www.chargerforums.com/forums/...d.php?t=186074
Cam and Header installation
Instructions and tips for doing a cam swap... --- PDF
https://www.chargerforums.com/forums/...ad.php?t=62387 --- PDF
https://www.chargerforums.com/forums/...ad.php?t=60390
Dipstick mod with headers
https://www.chargerforums.com/forums/...d.php?t=201714
Uninstalling/removing Underdrive Pulley
https://www.chargerforums.com/forums/...ad.php?t=97968 --- PDF
JBA Short-tube header install
'07 Charger 5.7 Hemi JBA Shorty Header Install & Review
Stock Thermostat Fan Settings (203*)
https://www.chargerforums.com/forums/...85&postcount=2
Replacing the thermostat --- Note: this video is by Powerwagon896 but his hosting provider died. I'm only using ******* pointing to my photobucket account to prevent the video from loading on this page and throwing off the formatting.
http://*******.com/lunl7s part 1 of 2
http://*******.com/lul2g8 part 2 of 2
25-cent Fan Mod
25-cent Fan Mod
Replacing radiator fans/assembly
https://www.chargerforums.com/forums/...d.php?t=144779 --- PDF
Performance 101
PIDs to log
robagd.com
Homemade CAI
25-cent Fan Mod
25-cent Fan Mod
part 2
How to build a Coolant Filter setup
https://www.chargerforums.com/forums/....php?p=1161063
Cooling system (radiator/block) coolant flush and fill
https://www.chargerforums.com/forums/...d.php?t=180753 --- PDF
Bleeding/burping radiator coolant
https://www.chargerforums.com/forums/...d.php?t=156642
Water pump replacement (3.5L)
https://www.chargerforums.com/forums/...d.php?t=190345
Budget Catch Can
https://www.chargerforums.com/forums/...ad.php?t=81500
How ESP Works
http://www.socallx.com/esp_modes.pdf
Disable ESP
https://www.chargerforums.com/forums/...ad.php?t=25225
https://www.chargerforums.com/forums/...d.php?t=109719
https://www.chargerforums.com/forums/...d.php?t=152678 (in cigarette lighter outlet) --- PDF
https://www.chargerforums.com/forums/...d.php?t=126646 (switch location)
ESP/BAS Disable with the turn of a key (cars built April 2006 and later)
https://www.chargerforums.com/forums/...ad.php?t=49079
How to change your oil
https://www.chargerforums.com/forums/...ad.php?t=97253
Removing factory oil filter
https://www.chargerforums.com/forums/...ad.php?t=59979
Reset Oil Change Reminder
https://www.chargerforums.com/forums/...d.php?t=117783
Installing Police (heavy duty) oil cooler
How to install Police HD Oil Cooler
Replacing oil pressure sensor
How to change the oil pressure sensor --- PDF
Zex Nitrous 5.7 Installation
https://www.chargerforums.com/forums/...ad.php?t=64207
https://www.chargerforums.com/forums/...ad.php?t=46544
Exhaust sound clips
https://www.chargerforums.com/forums/...ad.php?t=62492
Corsa Exhaust Installation
https://www.chargerforums.com/forums/...ad.php?t=17191
Installing R/T exhaust on V6
https://www.chargerforums.com/forums/...ad.php?t=81702 --- PDF
https://www.chargerforums.com/forums/...d.php?t=147813 --- PDF
Brylcreem mod (suitcase delete)
https://www.chargerforums.com/forums/...ad.php?t=18598
DMH Cutouts installation
https://www.chargerforums.com/forums/...ad.php?t=69304 --- PDF pt1 PDF pt2
Gutting the cats (catalytic converters)
https://www.chargerforums.com/forums/...ad.php?t=82520
Installing anti-foulers for O2 sensors after modding your cats
https://www.chargerforums.com/forums/....php?p=1402949
Installing Mopar Remote Start
https://www.chargerforums.com/forums/....php?p=1277515
Repairing the infamous Transmission (tranny) leak
https://www.chargerforums.com/forums/...d.php?t=104066
https://www.chargerforums.com/forums/...d.php?t=127261 --- PDF
Transmission fluid/filter change
https://www.chargerforums.com/forums/...d.php?t=127560 --- PDF pt1 PDF pt2
https://www.chargerforums.com/forums/...d.php?t=128544
Changing rear axle fluid
https://www.chargerforums.com/forums/....php?p=1538486
Getrag Installation (2006-200
https://www.chargerforums.com/forums/...d.php?t=150067
Firm up shifts - Blue Top solenoids
https://www.chargerforums.com/forums/...d.php?t=152006
Replacing Camshaft position sensor (fixes hard starting)
intermittent long start... fixed.
Replacing Crankshaft position sensor (fixes hard starting)
Crankshaft Position Sensor Replacement --- PDF
Trimming the EGR tube to eliminate false engine knock
https://www.chargerforums.com/forums/...d.php?t=110699 --- PDF
PCV Valve - check and replace (5.7L)
https://www.chargerforums.com/forums/...d.php?t=111966
Using Mopar TCM with Diablosport Predator
Mopar TCM and Predator Facts:
Replacing TCM
Transmission Control Module (TCM) Location and Access * --- PDF
Mopar TCM Calibration procedure
PDF
Removing engine cover and intake manifold (3.5L V6)
How to: 3.5L Lower Intake Manifold Installation --- PDF
Power Steering Maintenance
https://www.chargerforums.com/forums/...d.php?t=134337 --- PDF
https://www.chargerforums.com/forums/...d.php?t=144312
Replacing motor mounts
http://www.lxforums.com/board/f71/6-...ite-up-211304/
http://www.lxforums.com/board/f71/ne...review-189219/ --- PDF
Timing belt replacement (3.5 V6)
http://www.lxforums.com/board/f249/t...s-long-296580/ --- PDF
Autostick not working
https://www.chargerforums.com/forums/...d.php?t=228017
Budget Catch Can
How ESP Works
Disable ESP
Exhaust sound clips
Replacing TCM
