Waking up the Hemi
Old Apr 3, 2018 | 12:24 AM
Default Waking up the Hemi
https://www.youtube.com/watch?v=59cD3kEQ__g
[h=1]Waking up the Hemi[/h] 4,693 views
55 3 Share
Fast lane Lifestyle
In this video I will be doing a review of the fuse 2 pull on a 2012 Dodge Challenger R/T . As far as I know it will work on chargers as well
Old Apr 3, 2018 | 12:25 AM
https://www.youtube.com/watch?v=DqDwvM7Xs78
[h=1]Can a fuse give your car better performance???[/h] 3,405 views
45 4 Share
FLA HEMI
Published on Jan 5, 2018
What's UP YouTube. In this video I put to the test a simple procedure that could possibly make your car run a little better. I had seen a video fellow YouTuber @hemifam uploaded explaining the fuse pull procedure. Make sure to go check out his video!!! In my opinion I did notice a slight difference.
Old Apr 3, 2018 | 12:27 AM
https://www.youtube.com/watch?v=wvfefe2FqdY
[h=1]'14 Dodge Charger Fuse 31 Mod- Does it work?[/h] 9,464 views
27 2 Share
dasllamas
Published on Dec 24, 2016
So the theory is that if you remove fuse 31 for 10 minutes it will reset the ECU. Fuse 31 controls the fuel management system. After approximately 30 start / shut off cycles you need to reset the ECU again. There are people that swear by this and do it monthly. I test this for you in this video. Is this worth your time to do? I do lose 2 MPG after the reset. SRT Mod done with the Tazer by Zautomotive. https://www.youtube.com/watch?v=26T3T...
Old Apr 3, 2018 | 12:30 AM
https://www.youtube.com/watch?v=eIrTWgP8jhs
[h=1]Throttle Calibration- Relearn? Car Feels Different[/h] 27,195 views
349 13 Share
R/T Life
Let me know if you try it. After researching throttle relearn & calibration I may have stumbled onto something here. In the Charger/Challenger this method has resulted in the air intake being a little louder & my estimated gas mileage going up. There had to have been a throttle calibration or relearn in the 2015 2016 2017 Charger RT.
Old Apr 3, 2018 | 12:33 AM
https://www.youtube.com/watch?v=ykElI7ML4CM
[h=1]Throttle body relearn[/h] 31,597 views
45 9 Share
Simon Wilson
Throttle body relearn procedure for a Toyota Corrolla, Auris, Blade. Model shown is a 2007 Blade with 60,000km on the clock. with the instructions in the video. A throttle relearn is required if the throttle body is cleaned or replaced, or if the mass airflow sensor is cleaned or replaced.
Jul 3, 2021 03:43 PM
Na306StAnG
All American Street Car Performance
Dec 22, 2013 03:07 PM
16gAWD
Feb 26, 2003 10:44 AM
