Holding open the active exhaust......and how it works...
https://www.youtube.com/watch?time_c...&v=tcjWLgUkJi8
[h=1]Charger Hellcat Active Exhaust Simulator[/h] 7,762 views
131 11 Share
HonestlyOCD
Published on Mar 10, 2017
I've had this exhaust simulator installed on the Scat pack coupled with the mid muffler delete and I loved the results .. this product allows you to have open exhaust valves at all times regardless of RPM and driving mode .. at idle it sounds better and cruising around at low rpms even sounds much improved ..
I always felt like that little valve was not needed and this is the solution to eliminating that nonsense without having a code pop up or any other issues .. I highly recommend this and I will link to the purchasing page as well as the original install page from the creator .. ALSO .. I did not include a ton of exhaust clips because I plan on doing a video down the line covering exhaust related things
Active Exhaust Simulator Purchase Page: http://www.activeexhaustsolutions.com...
131 11 Share
Jul 3, 2021 03:43 PM
Paint, Body, and Detailing
Aug 5, 2014 09:19 PM
