the van project
Old Feb 5, 2003 | 10:58 PM
taka86fc's Avatar
Turbo>NA
The basically I should find a metal head gasket, injectors, tranny and torque converter. + if i want cali and might be taft cam.
Have you ever heard using a 60mm?? neon thlottlebody on 2.2/2.5? I just took a look at my friend's neon thlottle body. the design seems as same as 2.2/2.5. i know a machine shop and he can make the thlottle body wider. Should i try this?
Old Feb 6, 2003 | 06:08 AM
mpbiv's Avatar
Rod Bearing Eater
Some people don't even see much gain from going to a 52mm, so I'd say its probably not necesary. But if you did put it on you'd need to do a good bit of porting and possibly weld the manifold some.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
