Oh brain of mine, how cruel thou are!!!!
Whenever you have free time do you find yourself thinking, pondering, or imagining things you could build or do with your car or cars in general? Thats my dilema, I can't stop thinking about this stuff. I guess its why I chose to study mechanical engineering, because I really like to come up with designs and ways to improve things or make them my own way.
I have pretty much done all the thinking and planning I can with the turbo engine and the K. So thats pretty much set in stone. In the meantime my creative juices are still flowing, and I can't stop thinking about whats next after that.
I mentioned before I wouldn't mind trying a NA project, more specifically a 2.5NA DOHC Hybrid type engine. The more and more I think about the more detailed I notice that I am becoming. I keep coming up with ideas on how to make my ideas better. What started out as a thought to tinker with my old TBI block has become an obssession to build another car. And what was an obssession to build another has become an obssession to build a bad to the bone all motor FWD Dodge that would make a good weekend warrior at the autocross.
Being the engineer that I am I have been just adding to the list of things I would like to do. So here is a break down of the whole thing and it goes beyond just the engine and describes the car as well.
First I'll start with the engine and drivetrain:
-Rebuilt 2.5L NA Tall Block with adapted Neon DOHC head.
-2.5"Full exhaust treatment from the head to the exit.
-Higher compression, at least 10:1 I am thinking
-Different cams (figure that out later)
-Backut valves (would go with a full race head but they are always so expensive)
-Underdrive pulley
-Magnacore wires
-Adjustable cam pulleys
-Individual throttle bodies
-Custom carbon fiber timing belt cover (since there isn't any out for the 2.2/2.5 DOHC hybrid aps)
-Custom carbon fiber air box around throttle bodies with cold air duct to a naca (I thinks thats what its called) air scoop in the hood.
-555 or 568 trans
-custom calibrated 2.5 turbo computer and adapted harness (probably a wiring nightmare but who cares
Of course I'll need something to put this into, and I definitely think a Turismo is what I want. I just love the bodie lines and the 4 lamp headlight setup has always been my choice over the 2 lamp chargers. I would like to paint it black. It will also need some customary 5spoke 16" wheels and rubbers.
Next comes brakes and suspension, which is pretty much a no brainer:
-Full SLH3 conversion
-Cross drilled rotors
-Larger swaybars
-Strut/shock tower braces, front and rear
-Energy suspension bushings all around
-Koni's (of course, if they can be found that is)
-Lowering springs (1" or so would do, if they even exist)
I'd probably want to also freshen the interior up, just throw in new carpet and headliner and other parts as needed to make it look nice.
So I guess everyone is wondering why the hell I posted all this? Well it was driving me crazy and I just had to share. I seriously doubt I will ever get around to this, and if I do, it won't be for a long time (because the K comes first no matter what), but regardless I cannot stop thinking about it. I can picture the whole car and what it would look like in my head and its really driving me nuts
-Underdrive pulley
-Magnacore wires
-555 or 568 trans
)Of course I'll need something to put this into, and I definitely think a Turismo is what I want. I just love the bodie lines and the 4 lamp headlight setup has always been my choice over the 2 lamp chargers. I would like to paint it black. It will also need some customary 5spoke 16" wheels and rubbers.
-Larger swaybars
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
Ok well, you may doubt that you'll get around to it. But just to drive a little more crazy Jan 25th is 50% off day at the junkyard. They have 2.5L N/A Blocks. Usually they are 50 for a short block plus 15 for core. Complete engines are 160 plus 40 core Long blocks are 80 plus a 25 core. I'm already going there to get some stuff that I need. You could always build the engine one step at a time. You don't even have to put it in the K.
Actually I know the K will get done, in fact all my resources will be going directly into that first. The turbo K is top priority, what I do with the extra 2.5 Tall deck TBI block is something to consider later. This is just an idea I had, and how far it could go. It is definitely not going to happen soon unless I win the lottery. I won't even consider buying parts to start a NA DOHC project yet.
If anything in 2 years (about how much time I have to the K back on the road), I decide I still want to do that, I will start with just the engine. And if I finish said engine, then I will seek out another car to put it in. At this point there is no way in hell I would consider putting that TBI tall deck or any reincarnation back into the K. I certainly think it would be interesting engine, but I definitely would not be building it to put in my K.
I guess I talk about doing things too much without necesarily having the intention of doing them. I am definitely a dreamer, and I even tell myself to talk less do more. All I can guarantee at this point is the Turbo K will get done.
So I guess that brings me to the topic of my real project. I should be looking and probably buying my engine during spring break. Plans are to hit Cophers and hope I find something 89+. If I have any extra time left and depending on funds I will start buying major internal parts, pistons, rings, bearings etc. I would also like to check out some of the local machine shops by me and get an idea of what kind of shop bill I will have. Basically looking to have the block hot tanked and bored .020 over for new pistons. Probably have the rods resized or checked and the crank polished. The time window for that is looking like I will have a shortblock done by the end of June and then probably have the head, manifolds, and turbo ready by the end of summer. For the moment I am going to try and stick to those time frames. Other stuff like the transmission and wiring will come after that but I don't want to set any time frame for those yet. Other stuff like brake and suspension upgrades I won't do until the car is back on the road. That also means for a little while there will probably be a Hubcapped Turbo K running around
Patrick
Patrick
Guest
Posts: n/a
thats exactly how i am. and thats why i started going into Mech Engin.. but then it became way too theory for me and i got sick of it.
Hooray! Now you can forget about getting one of those impossible to find MP long headers and go with the mass produced neon headers!
maybe not. im talking with my calibrater right now and he really doesnt think making a cal for a neon head app would be hard. As long as you start with an SMEC preferably. You just add fuel and spark for whatever it needs. You may be a test mule for him, but the computer doesnt care what head or engine you have. Just as long as it supplies what's needed.
splurge and do coil overs! Someone on the FMML put them on his 87 GLHS
Patrick
Patrick
Originally posted by "FearThe4Doors"
let me know when we shall hit up CDM.. i'll keep updated on their stock
Patrick
Patrick
and i'll ask about the cal's
i forgot about the whole MPI thing.
I know he can write his own spark curve. Isnt the only reason it pulls timing is for detonation? There must be a table for that, which also can be rewritten.
Gary's site mentions things around it like a zener diode on the TPS to keep the computer from ever seeing WOT, but I'd rather have that fixed with a cal since it'd probably need new fuel tables anyways.
Patrick
Patrick
