HoRizon is getting fix0red
Been doing some things to keep the HoRizon in tip top shape. Finally got all the axle bearings all happy and quiet. Tonight (at like 2am) i went and pulled the axles so i can drop them off tomorrow to get rebuilt and have them ready for work on Thurs. My CDM drivers side ripped AGAIN and im sick of getting CDM ones every 2 mos, so i'm just getting them both built fresh.
In the meantime I picked up an oil pressure gauge sender b/c mine gives fluctuating oil pressure all the time. Somedays it is almost at 0 at idle and will never cross the 1/2 way mark.. then 20 min later it wont go lower than 1/2 way. The fuckin thing costed $25!!
I also got a new fuel filter since who knows when it was changed last. The car surges some almost like when its about to run out of gas... im thinking its starving with a plugged filter.
I'll also put on my new CDM RF door handle so Karen can get in by herself!
That should tide it over for a few more weeks. But in the not too distant future it needs a new steering rack and I may put struts on all 4 at that time, or possibly the week after. The car rides like its got these huge balloon tires.
After all that, it needs a little rust fix in the passenger side A-pillar on the outside where it meets the fender.
And to finish the car off, i'll build a 2.5 for it someday. This 2.2 is bitch slappin the pistons!
Oh yeah, I guess someday I should pull the A/C box and put in a new evaporator. It blew and now I have no A/C. I guess that can wait since summers almost over.
Lori, you say you can pull the box without taking the dash out?
LMAO Pull the box w/o removing the dahs??? Good Fucking Luck. Especially an A/C box. I know for a fact that it isn't going to happen. Heater only box maby, I know you can install a heater only w/o dash removal but it's a bitch.
haven't done a Omni or forgot how to but i pulled the big ol box out of my CSX without removing the dash it wasn't too bad pulled on the big box and rolled from under dash and the manual said it was not possible
I have no center console I bet I could get mine out with the dash in. But my AC would actually work if I would take the time to put some dye in and find out where its leaking. I know for a fact it works because I fixed it (needed a new expansion block), and it worked for a while until the freon all leaked out. So my box is staying in
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
