Magnum SB vs Old SB Mounts
Old Sep 12, 2002 | 06:24 PM
whore's Avatar
Default Magnum SB vs Old SB Mounts
Does anyone know how close the engine mounts are to each other? I always thought the magnum blocks were the same for the most part. But Jeff #2 says he thinks the mounts are diff. Schumacher doesnt make magnum -> pre-mag mounts.. so either its not needed, or people would never do that swap.
Old Sep 12, 2002 | 06:34 PM
leadfootedfool's Avatar
Eat soot
hey, unblock me l3ad fOOt3d fOOl
Old Sep 12, 2002 | 07:01 PM
Iroc Joe's Avatar
AuH20 in '64
Looking at the mount on my truck compared to the spool mount on my '73 block....They look the same. The magnum block casting is mostly the same, traditional SB bellhousings will bolt up, the mounts appear to be the same, however the head/intake, etc. bolt patterns are different.
My $.03
“If someone is so fearful that they are going to start using their weapons to protect their rights, it makes me very nervous that these people have weapons at all.”
U.S. Representative Henry Waxman (D-CA)
Originally Posted by XYNaPSE
Article I Section 8 gives Congress the power to do whatever Congress deems necessary.
Old Sep 12, 2002 | 09:24 PM
whore's Avatar
and what do you know about dodges?? :doublebird:
Old Sep 12, 2002 | 09:25 PM
whore's Avatar
thanks though. I did some research too and found about the same. The only diff was the mounts themself. The position should all be the same.
Old Sep 15, 2002 | 11:36 PM
whore's Avatar
i found this out a day or two ago. The mag block has both old LA ears, and the new mag mounts. I didnt update the thread though. THanks 808.
putting a mag into an old body is easy, putting a LA into a mag chasis is a little harder, but not too difficult i hear. Besides, schumacher makes mounts. I believe the mounts go to the frame, not the old mounts... so i could just air chisle off the mag mounts and put on the schumacher ones.
Old Sep 17, 2002 | 08:52 AM
whore's Avatar
guacaMOLie
Old Sep 17, 2002 | 08:53 AM
whore's Avatar
the schumacher mounts are $400 also... so maybe if i can find a 90-91 318 dak at a yard, i'll cut those mounts off. Also, and lori knows this.. look for one of those daks for me and snag me the oil pan
